The impressively sleek and durable HP 3-button USB laser mouse is designed for everyday performance and to complement your HP business notebook.
Laser tracking technology delivers variable speed precision on a variety of surfaces and the mouse wheel functions as a third button.
The mouse has no ball or moving parts, for improved durability and reduced sticking and cleaning. The contoured shape can be used in either hand.
Product Description | HP - mouse - USB | Device Type | Mouse | Connectivity Technology | Wired - USB | Orientation | Right and left-handed | Dimensions (WxDxH) | 6.27 cm x 11.5 cm x 3.7 cm | Weight | 102 g | Movement Detection Technology | Laser | Buttons Qty | 3 | Movement Resolution | 1000 dpi | Features | Scrolling wheel | Cables Included | USB cable - 1.83 m | OS Required | Microsoft Windows 7, Microsoft Windows Vista | Manufacturer Warranty | 1-year warranty |
General | |
Width | 6.27 cm |
Depth | 11.5 cm |
Height | 3.7 cm |
Weight | 102 g |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | RoHS |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
