Support the productivity of growing teams with simple, robust paper input accessories that enable media versatility and allow longer printing without reloading paper.
Product Description | HP media tray / feeder - 500 sheets | Product Type | Media tray / feeder | Colour | Black | Total Media Capacity | 500 sheets | Number of Media Trays | 1 | Dimensions (WxDxH) | 35.96 cm x 36.8 cm x 13.92 cm | Weight | 3.9 kg | Media Type | Plain paper | Media Sizes | Legal (216 x 356 mm), A4 (210 x 297 mm) | Manufacturer Warranty | 1-year warranty | Designed For | LaserJet Pro 400 M401a, 400 M401d, 400 M401dn, 400 M401dne, 400 M401dw, 400 M401n |
General | |
Dimensions (WxDxH) | 35.96 cm - 36.8 cm - 13.92 cm |
Weight | 3.9 kg |
Shipping Dimensions (WxDxH) / Weight | 49.5 cm x 46.8 cm x 25 cm / 5.1 kg |
Colour | Black |
Miscellaneous | |
Compliant Standards | REACH |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
Designed For | HP LaserJet Pro 400 M401a, 400 M401d, 400 M401dn, 400 M401dne, 400 M401dw, 400 M401n |
