Facilitate communication and collaboration with quality prints from clear, easily readable drawings to colorful presentatins. To help reduce downtime and improve productivity-and protect your investment-Original HP inks are designed with your HP DesignJet printer or MFP as an optimized printing system. Choose from a range of cartridge sizes from 40 to 300 ml. Take advantage of free, convenient ink cartridge return and recycling.
Move projects forward and facilitate team collaboration with quality prints from clear, easily readable drawings to colorful, powerful presentations. With Original HP inks, you get crisp, clear, accurate lines and vivid color.
Save time with hassle-free printing. To get the consistent quality you need, look to Original HP inks designed with your printer or MFP as an optimized printing system. Fast-drying, smudge-resistant prints help you keep the pace.
It's your choice. A range of cartridge sizes from 40- to 300-ml HP ink cartridges are designed to fit your print volume. Large supplies can reduce intervention. Ink cartridge return and recycling is free and convenient.
Product Description | HP 728 - cyan - original - DesignJet - ink cartridge | Product Type | Ink cartridge | Printing Technology | Ink-jet | HP Sub-brand | DesignJet | Printing Colour | Cyan | Capacity | 300 ml | Compatible with | DesignJet T730, T830 |
Consumable | |
Consumable Type | Ink cartridge |
Colour | Cyan |
Included Qty | 1-pack |
Capacity | 300 ml |
Compatibility Information | |
Compatible with | HP DesignJet T730, T830 |
