HP 772 300-ml Light Gray Designjet Ink Cartridges print with the same vivid colour and the same professional quality, over and over again. Original HP supplies are designed together with the printer to provide consistent, trouble-free printing.
Product Description | HP 772 - light grey - original - DesignJet - ink cartridge | Product Type | Ink cartridge | Printing Technology | Ink-jet | HP Sub-brand | DesignJet | Printing Colour | Light grey (pigmented) | Capacity | 300 ml | Compatible with | DesignJet HD Pro MFP, SD Pro MFP, Z5200 PostScript, Z5400 PostScript ePrinter |
General | |
Dimensions (WxDxH) / Weight | 440 g |
Shipping Width | 28.3 cm |
Shipping Depth | 4.1 cm |
Shipping Height | 11.8 cm |
Shipping Weight | 500 g |
Consumable | |
Consumable Type | Ink cartridge |
Included Qty | 1-pack |
Capacity | 300 ml |
Compatibility Information | |
Compatible with | HP DesignJet HD Pro MFP, SD Pro MFP, Z5200 PostScript, Z5400 PostScript ePrinter |
