Get consistent, professional-quality documents, using trusted Original HP toner cartridges. Stay productive and avoid wasted time and supplies. These reliable cartridges are specifically designed to work flawlessly with your HP LaserJet Pro.
Expect standout quality – and get it time after time – from Original HP toner cartridges. Avoid the reprints, wasted supplies, and costly delays that can occur with remanufactured cartridges.
Print professional-quality documents, using toner that produces crisp text and sharp black graphics.
Help keep business moving forward. Trust Original HP toner cartridges for consistent, uninterrupted printing that keeps you on task.
The choice you can trust – avoid frustrating reprints, wasted supplies, and delays.
Replace Original HP toner cartridges in seconds. They are specifically designed for your HP LaserJet printer or MFP and make installation quick and easy.
Get back to business quickly. Original HP toner cartridges are easy to install and replace.
Print with cartridges that are designed to conserve resources. Take advantage of easy recycling to help manage your environmental impact.
Help reduce your impact. Count on easy cartridge recycling at no charge through HP Planet Partners.
Product Description | HP 79A - black - original - LaserJet - toner cartridge (CF279A) | Product Type | Toner cartridge | Printing Technology | Laser | HP Sub-brand | LaserJet | Printing Colour | Black | Yield | Up to 1000 pages ISO/IEC 19752 | Compatible with | LaserJet Pro M12a, M12w, MFP M26a, MFP M26nw |
General | |
Dimensions (WxDxH) / Weight | 620 g |
Shipping Width | 37.5 cm |
Shipping Depth | 11.3 cm |
Shipping Height | 12.5 cm |
Shipping Weight | 830 g |
Consumable | |
Consumable Type | Toner cartridge |
Colour | Black |
Included Qty | 1-pack |
Compatibility Information | |
Compatible with | HP LaserJet Pro M12a, M12w, MFP M26a, MFP M26nw |
