Boost your productivity wherever your work takes you with the executive-class, full-sized the HP Elite x2 1012 G1 Advanced Keyboard.
Product Description | HP Advanced - keyboard - with NFC - dark grey | Device Type | Keyboard | Interface | Dock | Built-in Devices | NFC | Security Devices | Smart card reader | Colour | Dark grey | Dimensions (WxDxH) | 30 cm x 21.93 cm x 0.865 cm | Weight | 450 g | Designed For | Elite x2 1012 G1, 1012 G2; EliteBook x360 1012 G2 Notebook |
General | |
Interface | Dock |
Input Device | |
Width | 30 cm |
Depth | 21.93 cm |
Height | 0.865 cm |
Weight | 450 g |
Expansion / Connectivity | |
Interfaces | Dock |
Miscellaneous | |
Environmental Parameters | |
Min Operating Temperature | -15 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
Designed For | HP Elite x2 1012 G1, 1012 G2 , HP EliteBook x360 1012 G2 Notebook |
