The HP LaserJet Booklet Maker/Finisher provides the ability to create more complex finished documents in-house without the time and expense of going to an outside service.
Upgrade your printer to create more complex finished documents and improve your workflow.
Increase productivity and get additional output capacity of up to 3000 sheets.
Streamline print jobs and improve efficiency.
Product Description | HP finisher | Product Type | Finisher | Designed For | LaserJet Enterprise M806dn, M806x+, M806x+ NFC/Wireless direct; LaserJet Enterprise Flow MFP M830z, MFP M830z NFC/Wireless direct; LaserJet Managed Flow MFP M830zm |
General | |
Shipping Dimensions (WxDxH) / Weight | 128.1 cm x 109.5 cm x 84.8 cm / 115 kg |
Compatibility Information | |
Designed For | HP LaserJet Enterprise M806dn, M806x+, M806x+ NFC/Wireless direct , HP LaserJet Enterprise Flow MFP M830z, MFP M830z NFC/Wireless direct , HP LaserJet Managed Flow MFP M830zm |
