Enjoy easy data entry and wireless connectivity with the HP Wireless Business Slim Keyboard, designed to complement the 2015 class of HP Business PCs.
Multi-OS compatibility
Interact seamlessly with a full-sized keyboard layout that’s optimized for use with multiple operating systems
Connect wirelessly
Feel free to move around the desk or table with a keyboard that keeps working up to 30 ft (10 m) away from your PC through a 2.4 GHz wireless connection.
Handy LED indicator
Avoid surprises with a convenient LED that alerts you when you need to change the batteries.
Product Description | HP Business Slim - keypad and mouse set - UK Input Device | Device Type | Keypad and mouse set | Interface | 2.4 GHz | Wireless Receiver | USB wireless receiver | Connectivity Technology | Wireless | Localization and Layout | UK | Numeric Keypad | Yes | Pointing Device | Mouse - wireless - optical | Buttons Qty | 3 | Pricing Type | Promo | Manufacturer Warranty | 1-year warranty |
General | |
Max Operating Distance | Up to 10 m |
Dimensions (WxDxH) / Weight | Keyboard: 46.03 cm x 16.43 cm x 2.787 cm / 880 g , Mouse: 6.29 cm x 11.5 cm x 3.7 cm / 67 g , Wireless receiver: 1.84 cm x 4.55 cm x 0.84 cm / 5.9 g |
Type | Wireless |
Region | United Kingdom |
Keyboard Technology | Membrane |
Features | Numeric keypad |
Pointing Device | |
Type | Mouse - wireless |
Buttons Qty | 3 |
Movement Detection Technology | Optical |
Miscellaneous | |
Battery | |
Type | AAA type |
Required Qty | 2 |
Technology | Alkaline |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
