Empower students to create, collaborate, and learn with the HP Chromebook 11 EE. It offers the latest Intel processors, interactive tools, Android apps, enhanced connectivity, and a long battery life that recharges fast in a design that can withstand drops and minor spills.
Product Description | HP Chromebook 11 G7 Education Edition - 11.6" - Intel Celeron N4000 - 4 GB RAM - 16 GB eMMC - UK | Product Type | Chromebook | Operating System | Chrome OS - English | Processor | Intel Celeron N4000 / 1.1 GHz (2.6 GHz) / 4 MB Cache | Memory | 4 GB LPDDR4 (provided memory is soldered) | Storage | 16 GB eMMC | Display | 11.6" WLED 1366 x 768 / HD | Graphics | Intel UHD Graphics 600 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0 | Battery | 2-cell - up to 13 hours | Colour | Chalkboard grey | Dimensions (WxDxH) | 30.6 cm x 20.8 cm x 1.89 cm | Weight | 1.33 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Warranty | Limited warranty - parts and labour - 1 year |
General | |
Operating System | Google Chrome OS - English |
Processor / Chipset | |
CPU | Intel Celeron N4000 / 1.1 GHz |
Max Turbo Speed | 2.6 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | LPDDR4 SDRAM |
Speed | 3733 MHz |
Rated Speed | 3733 MHz |
Storage | |
Main Storage | 16 GB eMMC |
Display | |
Type | 11.6" - IPS |
LCD Backlight Technology | WLED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Colour Gamut | 67% sRGB |
Features | Slim Design, HD standard-viewing angle (SVA) eDP anti-glare |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 600 |
Camera | Yes - HD |
Video Resolutions | 720p |
Sound | Stereo speakers, microphone |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Wireless-AC 9560 - PCI Express Mini Card (M.2) |
Features | Miracast, dual stream (2x2) |
Compliant Standards | IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v |
Battery | |
Technology | 2-cell lithium polymer |
Capacity | 47.36 Wh |
Run Time | Up to 13 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 5 / 9 / 12 / 15 V |
Connections & Expansion | |
Interfaces | 2 x USB 3.1 Gen 1 (charging) , 2 x USB-C 3.1 (Power Delivery/data/video) , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Google Drive (100 GB Cloud Storage) (free for 1 year) |
Miscellaneous | |
Features | HP Fast Charge, Google H1 security chip |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | USB-C power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.33 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine |
Shock Tolerance (non-operating) | 240 g @ 2 ms half-sine |
Vibration Tolerance (operating) | 1.043 g @ RMS (random) |
Vibration Tolerance (non-operating) | 3.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
