Boost productivity in the office and school with the affordable and easy to manage HP Chromebox. Get quick access to data and effortless collaboration with your team using cloud based G Suite for business and Android applications.
Product Description | HP Chromebox G2 - mini - Core i7 8650U 1.9 GHz - 8 GB - SSD 32 GB | Type | Chromebox - mini | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Core i7 (8th Gen) 8650U / 1.9 GHz (, up to 4.2 GHz, (Quad-Core) | Cache Memory | 8 MB | Cache Per Processor | 8 MB | RAM | 8 GB (installed) / 16 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | SSD 32 GB - SATA - M.2 | Optical Storage | No optical drive | Card Reader | 3 in 1 | Graphics Controller | Intel UHD Graphics 620 | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2 | Power | AC 120/230 V (50/60 Hz) | OS Provided | Google Chrome OS | Colour | Black | Dimensions (WxDxH) | 14.93 cm x 14.93 cm x 4 cm | Weight | 570 g | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year |
General | |
Type | Chromebox |
Product Form Factor | Mini |
Built-in Devices | Speaker |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8650U |
Clock Speed | 1.9 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Cache Memory | |
Installed Size | 8 MB |
RAM | |
Installed Size | 8 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Slots | 2 (Total) / 0 (empty) |
Configuration Features | 2 x 4 GB |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 32 GB |
Interface Type | SATA |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | 3 in 1 card reader |
Supported Flash Memory Cards | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 620 |
Networking | |
Ethernet Controller | Realtek RTL8151GH-CG |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 7265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Interfaces | 1 x HDMI , 1 x USB-C , 3 x USB 3.0 (2 front, 1 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 2 x USB 2.0 |
Miscellaneous | |
Included Accessories | Power adapter |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | Low halogen |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Efficiency | 85% |
Operating System / Software | |
OS Provided | Google Chrome OS English |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 14.93 cm |
Depth | 14.93 cm |
Height | 4 cm |
Weight | 570 g |
