Height adjustable stand
Raise or lower the screen to suit each individual’s height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
Flicker Free
AOC flicker free technology utilises the DC (direct current) back light panel, reducing flickering light levels, which helps reduce eye strain and fatigue
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you’ll enjoy quality audio without the hassle of connecting external speakers.
AOC 24" 24P1
3-sides borderless 23.8" IPS display with Full HD
Sleek and elegant thanks to 3-sides borderless design, achieved thanks to the newest IPS panel in FHD (1920x1080px) resolution. Includes full range of display inputs (VGA, DVI, HDMI, DisplayPort), built-in speakers and improved ergonomic stand with 150 mm height adjustment.
Product Description | HP DreamColor Z31x Studio Display - LED monitor - 4K - 31.1" | Device Type | LED-backlit LCD monitor - 31.1" | Energy Class | Class G | Power Consumption (On mode) | 38.8 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 17:9 | Native Resolution | 4K 4096 x 2160 at 60 Hz | Pixel Pitch | 0.1704 mm | Brightness | 250 cd/m² | Contrast Ratio | 1500:1 | Response Time | 10 ms (On/Off) | Colour Support | 1.074 billion colours (10-bit) | Colour Gamut | 99% DCI-P3, 100% Adobe RGB, 100% BT.709, 100% sRGB, 80% BT.2020 | Input Connectors | 2xHDMI, 2xDisplayPort, USB-C | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 73.8 cm x 24.8 cm x 56.6 cm | Weight | 15 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, CSA, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, ICES, S Mark, MEPS, E-Standby, KC, CECP, CEL, Energy-using Products (EuP) Lot 5, SmartWay | Manufacturer Warranty | 5-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 31.1" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 149 |
Vertical Refresh Rate | 24 - 60 Hz |
Horizontal Refresh Rate | 30 - 135 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Picture in picture, picture by picture, Zero Bright Dot, sRGB colour management, HDCP, 10-bit gamma, integrated cable management, Low Blue Light Mode, Flicker Free technology, Mercury free, Colour Calibration, arsenic-free glass, remote calibration, script calibration |
Colour | Black |
Dimensions (WxDxH) | 73.8 cm x 24.8 cm x 56.6 cm - with stand |
Weight | 15 kg |
Connectivity | |
Interfaces | 2 x DisplayPort , 2 x HDMI , USB-C , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Height Adjustment | 144 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), fast charging |
Included Accessories | Stand |
Cables Included | 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x power cable - 1.9 m , 1 x USB-C cable - 1.8 m , 1 x USB-C to USB 3.0 type A cable - 1.8 m |
Backlight Life | 30,000 hours |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 38.8 kWh/1000h |
Power Consumption (Typical) | 120 Watt |
Power Consumption Stand by | 0.5 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 73.8 cm - depth: 24.8 cm - height: 56.6 cm - weight: 15 kg , Without stand - width: 73.8 cm - depth: 8.26 cm - height: 41.41 cm - weight: 9.9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
