The soul of a powerful PC inside a beautiful modular body, HP Elite Slice is like no desktop you've ever seen. Designed for the modern workforce, each compact, cable-less module adds functionality to transform Slice into something new.
Product Description | HP Elite Slice - Wireless Charging Top Cover - USFF - Core i7 6700T 2.8 GHz - vPro - 8 GB - SSD 512 GB - UK | Type | Personal computer - ultra small form factor | Platform Technology | Intel vPro Platform | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i7 (6th Gen) 6700T / 2.8 GHz (, up to 3.6 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 8 MB | Cache Per Processor | 8 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 512 GB - PCI Express 2.0 x4 - M.2 2280 - NVM Express (NVMe), HP Turbo Drive G2, triple-level cell (TLC) | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 530 | Audio Output | Stereo | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Skype, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), Windows Defender, HP Systems Software Manager (free download), HP Velocity, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), Windows 10 Welcome App, HP Sure Connect | Colour | Black sparkle, metal copper finish | Dimensions (WxDxH) | 16.5 cm x 16.5 cm x 3.55 cm | Weight | 1.05 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Ultra small form factor |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 1.2 and TPM 2.0) |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6700T |
Clock Speed | 2.8 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel Q170 |
Cache Memory | |
Installed Size | 8 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 512 GB |
Interface Type | PCI Express 2.0 x4 |
Features | NVM Express (NVMe), HP Turbo Drive G2, triple-level cell (TLC) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 530 |
Video Interfaces | HDMI, DisplayPort |
HDCP Compatible | Yes |
Max Monitors Supported | 3 |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Connectivity | Wireless |
Localization & Layout | UK |
Mouse | |
Networking | |
Ethernet Controller | Intel I219-LM |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8260 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1 |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.1 |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 1 (total) / 0 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280 , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU |
Interfaces | 1 x headphones/microphone , 2 x USB-C 3.1 Gen 1 , 2 x USB 3.1 - Type A (one of them with wake functionality, one of them is charging) , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) - RJ-45 |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | Energy-using Products (EuP) Lot 6, Common Criteria EAL4+, low halogen, Energy-Related Products (ErP) Lot 3, RoHS2 2.06, ACPI 5.08 |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 90 Watt |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | Skype, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), Windows Defender, HP Systems Software Manager (free download), HP Velocity, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), Windows 10 Welcome App, HP Sure Connect |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 16.5 cm |
Depth | 16.5 cm |
Height | 3.55 cm |
Weight | 1.05 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
