Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
Mobility and style without compromise
Strikingly thin and elegant, the Elite x2 1012 is a 2 in 1 for the mobile workforce and executives who want no compromises when it comes to enterprise-class power, durability, optional LTE connectivity and productivity on the go, in a stylish design.
Accessories built for how you work
At your desk or on the road, meet the specific needs of your work day with the included HP Active Pen with App Launch that uses Wacom technology. Accessorize to boost your efficiency. Add optional enterprise docking solutions and advanced keyboards
Designed for IT, loved by users
Stunning IT friendly design. Elite x2 1012 incorporates Elite global enterprise-class security and manageability features, enterprise-class durability, on-site serviceability,[2] global sku availability and support across 180 countries.
Performance to get the job done
The quiet fanless design and 10 hours of battery life8 lets you work, surf, and connect with colleagues.
The tools you need to succeed
Start, work, and transition between modes easily with Window 10 Pro.
Product Description | HP Elite x2 1012 G1 - 12" - Intel Core m5 - 6Y54 - 8 GB RAM - 256 GB SSD - 4G LTE - UK | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core m5 (6th Gen) - 6Y54 / 1.1 GHz, up to 2.7 GHz / 4 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Display | 12" LED backlight touchscreen 1920 x 1280 / WUXGA+ | Graphics | Intel HD Graphics 515 | Input Device | Keyboard, digital pen, ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Wireless Broadband (WWAN) | 4G LTE | Service Provider | HP Mobile Connect | Battery | 4-cell - up to 10.25 hours | Features | Ambient light sensor, proximity sensor, hall sensor | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) - tablet | 30 cm x 21.35 cm x 0.8 cm | Weight | 840 g | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz |
Max Turbo Speed | 2.7 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 12" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1280 (WUXGA+) |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Image Brightness | 340 cd/m² |
Features | Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4 |
Audio & Video | |
Graphics Processor | Intel HD Graphics 515 |
Camera | Yes - 1080p |
Resolution | 5 Megapixel (rear), 2 Megapixel (front) |
Camera Features | 1080p Full HD movie recording, low light enhancement, rear camera with flash |
Sound | Stereo speakers, two microphones |
Audio Features | Output: noise-cancellation technology, Bang & Olufsen Audio |
Input | |
Type | Keyboard, digital pen, ClickPad |
Keyboard Layout | UK |
Features | Volume control, touchpad with gesture support, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2) |
Features | Intel Wireless Display (WiDi) |
Compliant Standards | IEEE 802.11i, Wi-Fi CERTIFIED |
Wireless Broadband (WWAN) | |
Generation | 4G |
Technology | GPRS, EDGE, CDMA 2000 1X EV-DO Rev. A, LTE, DC-HSPA+ |
Controller | HP lt4120 - M.2 Card |
Navigation | |
Receiver | A-GPS/GPS/GLONASS |
Battery | |
Technology | 4-cell lithium polymer |
Installed Qty | 1 |
Max Supported Qty | 1 |
Capacity | 40 Wh |
Run Time | Up to 10.25 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt 1.4 A |
Connections & Expansion | |
Slots | 1 x Micro-SIM card (1 free) |
Interfaces Details | USB-C (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software |
Miscellaneous | |
Integrated Options | Ambient light sensor, proximity sensor, hall sensor |
Dockable | Yes |
Features | HP DuraKeys, HP SpareKey, built-in leg stand, Accelerometer, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | Power adapter, keyboard, HP Active Pen, HP Elite x2 1012 G1 Travel Keyboard |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 840 g |
Dimensions (WxDxH) / Weight Details | 30 cm x 21.35 cm x 1.345 cm / 1.205 kg - tablet with keyboard |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 240 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 1.043 g @ RMS (random) |
Vibration Tolerance (non-operating) | 3.5 g @ RMS (random) |
