Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
Product Description | HP Elite x2 1012 G1 - 12" - Intel Core m5 - 6Y57 - vPro - 8 GB RAM - 256 GB SSD - 4G LTE - UK | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit - English | Platform Technology | Intel vPro Platform | Processor | Intel Core m5 (6th Gen) - 6Y57 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Display | 12" LED backlight touchscreen 1920 x 1280 / WUXGA+ | Graphics | Intel HD Graphics 515 | Input Device | Keyboard, digital pen, ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Wireless Broadband (WWAN) | 4G LTE | Service Provider | Service not included | Battery | 4-cell - up to 10.25 hours | Features | Ambient light sensor, proximity sensor, hall sensor | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) - tablet | 30 cm x 21.35 cm x 0.805 cm | Weight | 820 g | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core m5 (6th Gen) 6Y57 / 1.1 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 12" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1280 (WUXGA+) |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Image Brightness | 340 cd/m² |
Features | Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4 |
Audio & Video | |
Graphics Processor | Intel HD Graphics 515 |
Camera | Yes - 1080p |
Resolution | 5 Megapixel (rear), 2 Megapixel (front) |
Camera Features | 1080p Full HD movie recording, low light enhancement, rear camera with flash |
Sound | Stereo speakers, two microphones |
Audio Features | Output: noise-cancellation technology, Bang & Olufsen Audio |
Input | |
Type | Keyboard, digital pen, ClickPad |
Keyboard Layout | UK |
Features | Volume control, touchpad with gesture support, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | PCI Express Mini Card (M.2) |
Features | Intel Wireless Display (WiDi) |
Compliant Standards | IEEE 802.11i, Wi-Fi CERTIFIED |
Wireless Broadband (WWAN) | |
Generation | 4G |
Technology | GPRS, EDGE, CDMA 2000 1X EV-DO Rev. A, LTE, DC-HSPA+ |
Controller | M.2 Card |
Navigation | |
Receiver | A-GPS/GPS/GLONASS |
Battery | |
Technology | 4-cell lithium polymer |
Installed Qty | 1 |
Max Supported Qty | 1 |
Capacity | 40 Wh |
Run Time | Up to 10.25 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 5 / 12 / 15 V, 1.4 A |
Connections & Expansion | |
Slots | 1 x Micro-SIM card (1 free) |
Interfaces Details | USB-C (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software |
Miscellaneous | |
Integrated Options | Ambient light sensor, proximity sensor, hall sensor |
Dockable | Yes |
Features | HP DuraKeys, HP SpareKey, Accelerometer, built-in adjustable tilt stand, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | Power adapter, keyboard, HP Active Pen, HP Elite x2 1012 G1 Travel Keyboard |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 820 g |
Dimensions (WxDxH) / Weight Details | 30 cm x 21.35 cm x 13.45 cm / 1.205 kg - tablet with keyboard , 30 cm x 21.93 cm x 0.61 cm / 385 g - keyboard dock |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 240 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 1.043 g @ RMS (random) |
Vibration Tolerance (non-operating) | 3.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
