The sophisticated style of the HP EliteBook 1040 Ultrabook complements the innovative performance, security, and manageability features that help bring out your finest work.
Product Description | HP EliteBook 1040 G3 Notebook - 14" - Intel Core i5 - 6200U - vPro - 8 GB RAM - 256 GB SSD - UK | Product Type | Ultrabook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English | Platform Technology | Intel vPro Platform | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 8 GB DDR4 (provided memory is soldered) | Storage | 256 GB SSD | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 520 | Input Device | Trackpad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet | Battery | 6-cell | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 33.7 cm x 23.45 cm x 1.58 cm | Weight | 1.43 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Slim Design, Full HD standard-viewing angle (SVA) anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, trackpad |
Keyboard Layout | UK |
Features | Spill-resistant, etched-glass touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, NFC, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I218-LM |
Compliant Standards | IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 6-cell lithium polymer |
Capacity | 45.6 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | HDMI , Headphone/microphone combo jack , Dock , 2 x USB 3.0 |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, HP Setup, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, Intel Wireless Display, HP Wallpaper, HP Spare Key, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP Security Manager, Drive Encryption, HP Ceement, HP Manageability, HP BIOSphere, HP Software Setup, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download) |
Miscellaneous | |
Case Material | Magnesium-aluminum alloy |
Dockable | Yes |
Features | HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, 2 x USB 3.0 charging port |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.43 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Get more from your purchase from one of our essential accessories
