With 360° of versatility across five modes, unmatched security, and long hours of battery life, the thin and light HP EliteBook x360 1030 is the perfect PC for highly mobile professionals. Wherever business or pleasure takes you, set another benchmark for work and fun.
Product Description | HP EliteBook x360 1020 G2 Notebook - 12.5" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook - flip design | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD - NVMe, TLC | Display | 12.5" LED backlight touchscreen 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Input Device | ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | 4-cell | Features | Hood sensor | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) | 29 cm x 20.38 cm x 1.39 cm | Weight | 1.13 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years , Limited warranty - battery - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7500U / 2.7 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC) |
Display | |
Type | 12.5" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Ultra Slim Design, Direct Bonding technology, Corning Gorilla glass 4, Full HD ultra wide-viewing angle (UWVA) eDP +PSR |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Camera Features | IR camera, Windows Hello |
Sound | Stereo speakers, dual array microphone |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Volume control, multi-touch touchpad, glass with chemical etched surface |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2) |
Features | Miracast, dual stream (2x2) |
Compliant Standards | IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 49.28 Wh |
AC Adapter | |
Output | 65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V |
Connections & Expansion | |
Interfaces Details | 2 x USB-C 3.1 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack |
Miscellaneous | |
Case Material | Aluminum |
Integrated Options | Hood sensor |
Features | Power-on password, HP DuraKeys, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, adjustable angle (5 positions), HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3 |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | USB-C power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.13 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - battery - 3 years |
