The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide an enterprise-class experience to meet virtually any business need.
Fit user needs and the budget
Power your PC with the latest 7th generation AMD Pro A-Series APUs and upgrade your system with up to 64 GB of DDR4 memory, the latest SSD drives, graphics, and HP accessories without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start Gen 3, AMD Secure Processor, and TPM 2.0.
Reliability for the long haul
This work-ready PC is designed with platform stability up to 18 months for a long life cycle. Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G3 testing.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
Product Description | HP EliteDesk 705 G3 - micro tower - A6 9500 3.5 GHz - 8 GB - HDD 500 GB - TAA Compliant | Type | Personal computer - micro tower | Localisation | Language: English / region: United Kingdom | Processor | AMD A6 9500 / 3.5 GHz (, up to 3.8 GHz, (Dual-Core) | Cache Memory | 1 MB L2 Cache | Cache Per Processor | 1 MB | RAM | 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | HDD 500 GB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD SuperMulti | Graphics Controller | AMD Radeon R5 | Audio Output | Stereo | Networking | 1GbE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Systems Software Manager, Windows Defender, HP BIOSphere, CyberLink Power Media Player, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Image Assistant, HP JumpStart | Dimensions (WxDxH) | 17 cm x 34 cm x 35.5 cm | Weight | 6.76 kg | TAA Compliant | Yes | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Micro tower |
Built-in Devices | Solenoid hood lock |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | AMD A6 9500 |
Clock Speed | 3.5 GHz |
Max Turbo Speed | 3.8 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | AMD B350 FCH |
Cache Memory | |
Installed Size | L2 Cache - 1 MB |
RAM | |
Installed Size | 8 GB / 64 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 3 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R5 |
Video Interfaces | VGA, DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Input Device | |
Type | Mouse |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Ethernet Controller | Broadcom BCM5762 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol | ASF 2.0 |
Features | Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" |
Slots | 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height |
Interfaces | 6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, RoHS, WEEE, Common Criteria EAL4+ |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 280 Watt |
Efficiency | 93% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Systems Software Manager, Windows Defender, HP BIOSphere, CyberLink Power Media Player, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Image Assistant, HP JumpStart |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 17 cm |
Depth | 34 cm |
Height | 35.5 cm |
Weight | 6.76 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
