The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide an enterprise-class experience to meet virtually any business need.
Product Description | HP EliteDesk 705 G3 - SFF - A10 PRO-9700 3.5 GHz - 8 GB - HDD 500 GB - UK - TAA Compliant | Type | Personal computer - small form factor | Localisation | Language: English / region: United Kingdom | Processor | AMD A10 PRO-9700 / 3.5 GHz (, up to 3.8 GHz, (Quad-Core) | Cache Memory | 2 MB L2 Cache | Cache Per Processor | 2 MB | RAM | 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | HDD 500 GB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD SuperMulti | Graphics Controller | AMD Radeon R7 | Audio Output | Stereo | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart | Dimensions (WxDxH) | 38 cm x 33.8 cm x 10 cm | Weight | 6.6 kg | TAA Compliant | Yes | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | AMD A10 PRO-9700 |
Clock Speed | 3.5 GHz |
Max Turbo Speed | 3.8 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | AMD B350 FCH |
Cache Memory | |
Installed Size | L2 Cache - 2 MB |
RAM | |
Installed Size | 8 GB / 64 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 3 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R7 |
Video Interfaces | VGA, DisplayPort |
HDCP Compatible | Yes |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP USB Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Ethernet Controller | Broadcom BCM5762 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol | ASF 2.0 |
Features | Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H |
Slots | 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x8 mode) |
Interfaces | 4 x USB 2.0 (2 front, 2 rear) (one of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 2 |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, CCC, RoHS, WEEE, Common Criteria EAL4+, low halogen |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 200 Watt |
80 PLUS Certification | 80 PLUS Platinum |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 38 cm |
Depth | 33.8 cm |
Height | 10 cm |
Weight | 6.6 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
