Powered for the enterprise, the HP EliteDesk 705 SFF is one of our most secure PCs that delivers impressive value with the performance required by today's high-productivity workforce in a new space-saving and stylish design.
Product Description | HP EliteDesk 705 G4 - SFF - Ryzen 3 Pro 2200G 3.5 GHz - 8 GB - SSD 256 GB - UK | Type | Personal computer - small form factor | Localisation | Language: English / region: United Kingdom | Processor | AMD Ryzen 3 Pro 2200G / 3.5 GHz (3.7 GHz) (Quad-Core) | Cache Memory | 4 MB | Cache Per Processor | 4 MB | RAM | 8 GB (installed) / 64 GB (max) - DDR4 SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe) | Optical Storage | DVD-Writer | Graphics Controller | AMD Radeon Vega 8 | Audio Output | Stereo | Networking | GigE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 29.6 cm x 27 cm x 9.5 cm | Weight | 4.53 kg | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | AMD Ryzen 3 Pro 2200G / 3.5 GHz |
Max Turbo Speed | 3.7 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | AMD B350 FCH |
Cache Memory | |
Installed Size | 4 MB |
RAM | |
Installed Size | 8 GB / 64 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 3 (empty) |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD-Writer |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon Vega 8 |
Video Interfaces | VGA, DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111EPH |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X), PXE 2.1 support |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 1 (free) x internal 2x2.5" / 1x3.5" shared |
Slots | 1 (total) / 1 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2230/2280 (x2 mode) |
Interfaces | 6 x USB 2.0 (2 front, 4 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x USB-C 3.0 (1 in front) , 2 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
80 PLUS Certification | 80 PLUS Platinum |
Efficiency | 92% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 29.6 cm |
Depth | 27 cm |
Height | 9.5 cm |
Weight | 4.53 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 39.9 cm |
Shipping Depth | 23 cm |
Shipping Height | 49.9 cm |
Shipping Weight | 7.32 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 5 - 90% |
