Powered for the enterprise, the HP EliteDesk 800 is a secure and manageable PC. It features the performance required by today's workforce and a stylishly redesigned chassis for the modern workplace.
Product Description | HP EliteDesk 800 G3 - SFF - Core i7 7700 3.6 GHz - vPro - 8 GB - SSD 256 GB - UK | Type | Personal computer - small form factor | Platform Technology | Intel vPro Platform | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i7 (7th Gen) 7700 / 3.6 GHz (, up to 4.2 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 8 MB | Cache Per Processor | 8 MB | RAM | 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC) | Optical Storage | DVD-Writer | Graphics Controller | Intel HD Graphics 630 Dynamic Video Memory Technology | Audio Output | Stereo | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP Client Security Suite Gen3, HP Notifications, HP Manageability & Integration Kit | Dimensions (WxDxH) | 38.8 cm x 30.8 cm x 10 cm | Weight | 5.31 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site - response time: next business day |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7700 |
Clock Speed | 3.6 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel Q270 |
Cache Memory | |
Installed Size | 8 MB |
RAM | |
Installed Size | 8 GB / 64 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 3 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | NVM Express (NVMe), triple-level cell (TLC) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 Dynamic Video Memory Technology |
Video Interfaces | DisplayPort |
HDCP Compatible | Yes |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 2 (total) / 2 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 2.5" x 1/8H |
Slots | 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile |
Interfaces | 6 x USB 3.1 Gen 1 (2 front, 4 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x audio line-out , 1 x audio line-in , 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 1 x VGA |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, CCC, Common Criteria EAL4+, CECP, SEPA, low halogen |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 82% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP Client Security Suite Gen3, HP Notifications, HP Manageability & Integration Kit |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site - response time: next business day |
Dimensions & Weight | |
Width | 38.8 cm |
Depth | 30.8 cm |
Height | 10 cm |
Weight | 5.31 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
