Meetings come to life on your choice of AiO displays that transform your workspace into a rich video conferencing solution with immersive video and audio engagement, capacitive touch controls, and a built-in pop-up privacy camera.
Product Description | HP EliteOne 1000 G1 - all-in-one - Core i7 7700 3.6 GHz - 8 GB - SSD 256 GB - LED 27" | Type | Personal computer - all-in-one | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i7 (7th Gen) 7700 / 3.6 GHz (, up to 4.2 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 8 MB | Cache Per Processor | 8 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe) | Optical Storage | No optical drive | Monitor | 27" - LED - 3840 x 2160 (Ultra HD 4K) - 16:9 | Graphics Controller | Intel HD Graphics 630 | Camera | Yes | Audio Output | Stereo | Networking | 1GbE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 61.33 cm x 19 cm x 45.73 cm | Weight | 10.2 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Personal computer |
Product Form Factor | All-in-one |
Built-in Devices | Fingerprint reader |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7700 |
Clock Speed | 3.6 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel Q270 |
Cache Memory | |
Installed Size | 8 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | LED - IPS |
Diagonal Size | 27" |
Native Resolution | 3840 x 2160 (Ultra HD 4K) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Colour Gamut | 99% sRGB |
Pixel Pitch | 0.1554 mm |
Image Brightness | 350 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | Ultra HD 4K anti-glare, 99% sRGB colour gamut |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | HDMI, DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Speakers Included | 2 x right / left channel |
Camera | |
Camera | Yes |
Resolution (MP) | 2 Megapixel (rear), 2 Megapixel (front) |
Resolution | Full HD |
Features | IR camera, Windows Hello |
Audio Input | |
Type | Dual array microphone |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" x 1/8H |
Slots | 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280 |
Interfaces | 5 x USB 3.1 Gen 1 (two of them with wake functionality, one of them is charging) , 1 x DisplayPort input , 1 x DisplayPort output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x USB 3.1 - Type C |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 87% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 61.33 cm |
Depth | 19 cm |
Height | 45.73 cm |
Weight | 10.2 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 95% (non-condensing) |
