This HP Colour LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network with the industry's deepest security.
Product Description | HP Color LaserJet Enterprise M653dn - printer - colour - laser | Printer Type | Workgroup printer - laser - colour | Weight | 31.3 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 56 ppm - black normal - A4 (210 x 297 mm) , Up to 56 ppm - colour normal - A4 (210 x 297 mm) , Up to 74 ppm - B/W - A5 (148 x 210 mm) , Up to 74 ppm - colour - A5 (148 x 210 mm) , Up to 56 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 56 ipm - colour duplex - A4 (210 x 297 mm) , Up to 60 ppm - ANSI A (Letter) (216 x 279 mm) , Up to 60 ppm - duplex - ANSI A (Letter) (216 x 279 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Max Resolution (Colour) | 1200 x 1200 dpi | Image Enhancement Technology | HP ImageRet 3600 / HP ProRes 1200 | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, USB 2.0 host | AirPrint Enabled | Yes | Preview Screen Size | 4.3" | Processor | 1.2 GHz | RAM Installed (Max) | 1 GB (2 GB) - DDR3 SDRAM - DIMM 144-pin | Flash Memory Installed (Max) | 8 GB | Language Simulation | PCL 5C, PostScript 3, PCL 6, PDF 1.7, URF | Media Type | Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, opaque film, paper, middle thick paper, card stock, extra heavy-weight paper, light-weight paper, soft gloss paper, preprinted paper, postcards, glossy paper | Total Media Capacity | 650 sheets | Media Handling | 100-sheet multipurpose tray, 550-sheet input tray | Monthly Duty Cycle (max) | 120000 pages | Recommended Monthly Volume | 3000 - 17000 pages | Networking | Print server | Printer Features | Hardware integration pocket, Instant-on Technology, Auto Power On, Auto Power Off | System Requirements | UNIX, Microsoft Windows Vista (32-bit versions), Citrix MetaFrame XP Presentation Server, Citrix MetaFrame Presentation Server 3.0, Android, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Server 2008 (32/64-bits) SP2, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Citrix XenApp 6.0 64-bit, Citrix XenApp 6, Citrix XenApp 5 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Citrix XenApp 6.5 64-bit, Citrix XenApp 6.5, Windows 8.1 (32/64 bits), Novell Open Enterprise Server 11 SP1, Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple MacOS X 10.10, Citrix XenDesktop 5.6, Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Novell NetWare 6.5 SP8, Ubuntu Linux 14.04, Apple MacOS X 10.11, Microsoft Windows Server 2012 R2 (32/64 bits), Citrix XenApp 7.5, Citrix XenDesktop 7, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS Sierra 10.12 or later, Linux Mint 17.2, Linux Mint 17.3, Microsoft Windows Server 2003 R2 (32/64-bits) SP2, SUSE Linux 13.2, Ubuntu Linux 16, Linux Mint 18, Citrix XenDesktop 7.5 | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 51 cm x 45.8 cm x 51 cm |
General | |
Printer | |
Built-in Devices | 4.3 inch LCD touch screen |
Connectivity Technology | Wired |
PostScript Support | Standard |
Fonts Included | 105 x TrueType , 92 x PostScript 3 |
Processor | |
RAM | |
RAM Installed (Max) | 1 GB / 2 GB (max) |
Technology / Form Factor | DDR3 SDRAM - DIMM 144-pin |
Slots Qty | 1 |
Flash Memory | |
Flash Memory | 8 GB |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, 76.2 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, RA4 (215 x 305 mm), 101.6 x 148 mm |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Media Weight | 60 g/m² - 220 g/m² |
Media Feeders | 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² |
Max Media Capacity | 3200 sheets |
Output Trays Capacity | 500 sheets |
Duty Cycle | |
Networking | |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, IPPS, SLP |
Security Protocols & Features | Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP |
Expansion / Connectivity | |
Connections | 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 12500 pages , 1 x toner cartridge (cyan) - up to 10500 pages , 1 x toner cartridge (magenta) - up to 10500 pages , 1 x toner cartridge (yellow) - up to 10500 pages |
Features | Security lock slot (cable lock sold separately) |
Compliant Standards | UL, CISPR 22 Class A, cUL, GS, CECP, EN 62479:2010, EN 61000-3-3:2013, EN 55024:2010, EMC 2014/30/EU, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, FCC CFR47 Part 15 A, ICES-003 issue 6 Class A, CISPR 32:2012 Class A, EN 55032:2012 Class A, IEC/EN60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, IEC/EN 60825-1:2014 Class 1 |
Security Slot Type | Kensington security slot |
Power | |
Power Device | Power supply - internal |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 690 Watt |
Power Consumption Stand by | 31 Watt |
Power Consumption Sleep | 0.7 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, HP Device Experience (DXP), HP Connected |
OS Required | UNIX, Microsoft Windows Vista (32-bit versions), Citrix MetaFrame XP Presentation Server, Citrix MetaFrame Presentation Server 3.0, Android, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Server 2008 (32/64-bits) SP2, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Citrix XenApp 6.0 64-bit, Citrix XenApp 6, Citrix XenApp 5 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Citrix XenApp 6.5 64-bit, Citrix XenApp 6.5, Windows 8.1 (32/64 bits), Novell Open Enterprise Server 11 SP1, Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple MacOS X 10.10, Citrix XenDesktop 5.6, Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Novell NetWare 6.5 SP8, Ubuntu Linux 14.04, Apple MacOS X 10.11, Microsoft Windows Server 2012 R2 (32/64 bits), Citrix XenApp 7.5, Citrix XenDesktop 7, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS Sierra 10.12 or later, Linux Mint 17.2, Linux Mint 17.3, Microsoft Windows Server 2003 R2 (32/64-bits) SP2, SUSE Linux 13.2, Ubuntu Linux 16, Linux Mint 18, Citrix XenDesktop 7.5 |
System Requirements Details | Windows XP/Vista/7/8/8.1/10 - HD 2 GB , MacOS X 10.0 or later - HD 1.3 GB |
Environmental Standards | |
Blue Angel | Yes |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% |
Sound Emission (Operating) | 54 dBA |
Dimensions & Weight | |
Width | 51 cm |
Depth | 45.8 cm |
Height | 51 cm |
Weight | 31.3 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 65.3 cm |
Depth (Shipping) | 59.6 cm |
Height (Shipping) | 57.8 cm |
Weight (Shipping) | 36 kg |
