HP LaserJet Pro - large-format printer - colour - ink-jet
Product Description | HP LaserJet Pro M12a - printer - B/W - laser | Printer Type | Workgroup printer - laser - B/W | Weight | 5.2 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 147 mm x 211 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 19 ppm - B/W - Legal (216 x 356 mm) | Max Resolution (B&W) | 600 x 600 dpi | Image Enhancement Technology | HP FastRes 1200 | Interface | USB 2.0 | Processor | 266 MHz | RAM Installed (Max) | 8 MB (8 MB) | Media Type | Envelopes, transparencies, labels, plain paper, photo paper, card stock, postcards, vellum paper | Total Media Capacity | 150 sheets | Media Handling | 150-sheet input tray | Monthly Duty Cycle (max) | 5000 pages | Recommended Monthly Volume | 100 - 1000 pages | System Requirements | Microsoft Windows Vista / XP, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits) | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 34.9 cm x 23.8 cm x 19.6 cm |
General | |
Printer Type | Workgroup printer - laser - monochrome |
Printer | |
Connectivity Technology | Wired |
First Print Out Time B/W | 9.2 sec |
Processor | |
RAM | |
RAM Installed (Max) | 8 MB / 8 MB (max) |
Media Handling | |
Media Sizes | Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 147 x 211 mm |
Envelope Sizes | International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm) |
Media Weight | 60 g/m² - 163 g/m² |
Media Feeders | 1 x automatic - 150 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² |
Output Trays Capacity | 100 sheets |
Duty Cycle | |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 500 pages |
Compliant Standards | EN 62479:2010, GB 4943-2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60825-1:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Power | |
Power Device | Power supply - internal |
Frequency Required | 50 Hz |
Power Consumption Operational | 375 Watt |
Power Consumption Stand by | 1.2 Watt |
Power Consumption Sleep | 0.8 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, HP Status and Alerts |
OS Required | Microsoft Windows Vista / XP, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits) |
System Requirements Details | Windows 7/8/8.1/10 - RAM 1 GB - HD 400 MB , Windows Vista - RAM 1 GB - HD 750 MB , Windows Server 2003/2008 - RAM 512 MB - HD 400 MB |
Environmental Standards | |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 32.5 °C |
Humidity Range Operating | 10 - 80% |
Sound Emission (Operating) | 50 dBA |
Dimensions & Weight | |
Width | 34.9 cm |
Depth | 23.8 cm |
Height | 19.6 cm |
Weight | 5.2 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 40 cm |
Depth (Shipping) | 25 cm |
Height (Shipping) | 29.8 cm |
Weight (Shipping) | 6.35 kg |
