ITEM | QTY | PRICE |
StarTech.com 3 Port 2b 1a Low Profile...
2 | £132.20 |
Samsung 32" T5300 Full HD HDR Sm...
4 | £956.00 |
HP 250 G9 Botebook Intel Core i5-1235...
3 | £2,343.81 |
Say hello to the wide format professional colour inkjet printer for your growing business from the World's #1 Printer Company, paired with the easiest-to-use print app. Print and scan up to A3 with extra performance features.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
Product Description | HP Officejet Pro 9730e Wide Format All-in-One - multifunction printer - colour | Device Type | Multifunction printer | Localisation | United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 30000 pages | Recommended Monthly Volume | 250 - 1500 pages | Max Copying Speed | Up to 18 ppm (mono) / up to 13 ppm (colour) | Max Copying Resolution | Up to 600 dpi (mono) / up to 600 dpi (colour) | Max Printing Speed | Up to 22 ppm (mono) / up to 18 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Scanning | 1200 x 1200 dpi | Display | 4.3" | Original Size | 76 x 127 mm (min) - A3/Ledger (297 x 432 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 76 x 127 mm (min) - A3 (297 x 420 mm) (max) | Media Type | Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper | Standard Media Capacity | 250 sheets | Max Media Capacity | 500 sheets | Output Trays Capacity | 75 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, LAN, USB 2.0 host, Wi-Fi(ac), Bluetooth LE | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to e-mail, Mopria certified, scan to memory card, scan to SharePoint, scan to PC, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 58.1 cm x 46.7 cm x 38.6 cm | Weight | 19.5 kg | Enclosure Colour | Cement | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 4.3" |
Display Colour Support | Colour |
Display Features | Touch screen |
Memory | |
Standard Memory | 512 MB |
Max Supported Memory | 512 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Automatic Duplexing | Yes |
Copying Features | ID Card Copy, collation copy, margin shift, quality adjustment, 2-sided copy orientation change, resize |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 1568 nozzles (black), 6272 nozzles (colour) |
Ink Cartridge Configuration | 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black) |
Ink Palette Supported (Colours) | Pigment cyan, pigment magenta, pigment yellow, pigment black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3e, PCL 3 GUI |
First Print Out Time B/W | 12 sec |
First Print Out Time Colour | 13 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Document & Media Handling | |
Min Original Size | 76 x 127 mm |
Max Original Size | A3/Ledger (297 x 432 mm) |
Min Media Size | 76 x 127 mm |
Max Media Size | A3 |
Min Media Weight | 60 g/m² |
Max Media Weight | 180 g/m² |
Min Media Weight (lb) | 16 lbs |
Supported Media Type | Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm) |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm) |
Borderless Photo Sizes | A3 (297 x 420 mm) |
Document & Media Handling Details | ADF - 35 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , 2 x input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets |
Speed Details | Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 26 ppm (A4) - colour draft , Copying: up to 34 ppm (Letter A) - B/W draft , Copying: up to 26 ppm (Letter A) - colour draft , Copying: up to 18 ppm - B/W (ISO) , Copying: up to 13 ppm - colour (ISO) , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft , Scanning: up to 8 ipm (A4) - B/W normal , Scanning: up to 6 ipm (A4) - colour normal , Scanning: up to 14 ipm (A4) - B/W duplex normal , Scanning: up to 11 ipm (A4) - colour duplex normal |
Connections | |
Interfaces | 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | SSL, TLS |
Operating System Support | Linux, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, macOS 10.13, macOS 10.12.x |
Software Included | HP Photo Creations, HP Update, Google Toolbar, Software HP Printer |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Standby | 5.4 Watt |
Power Consumption Sleep | 1.39 Watt |
Miscellaneous | |
Included Accessories | Setup poster |
Consumables Included | 1 x toner cartridge (black) - HP 937 , 1 x toner cartridge (cyan) - HP 937 , 1 x toner cartridge (magenta) - HP 937 , 1 x toner cartridge (yellow) - HP 937 |
Compliant Standards | BSMI, GOST, GS, CCC, EMC, FCC CFR47 Part 68, UL 60950-1 Second Edition, WEEE, ANATEL, AS/NZS 60950, AS/ACIF S002, NOM-019-SCFI-1998, ICASA, Subtel, GB4943.1-2001, IEC 60950-1:2001, R&TTE Directive 1999/5/EC, EN 60825-1:1994 + A1:2002 + A2:2001, SPRING, CNC, EU RoHS, CS-03 issue 9:2010, TIA/EIA-968:2001, SCT, AS/NZS 60950-1:2003, CAN/CSA-C22.2 No. 60950-1-07, EN 60950-1:2001 + A11:2004, CISPR 22:2006, TBR21:1998 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 58.1 cm |
Depth | 46.7 cm |
Height | 38.6 cm |
Weight | 19.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 66.8 cm |
Shipping Depth | 54.5 cm |
Shipping Height | 48.7 cm |
Shipping Weight | 24.45 kg |
Environmental Parameters | |
Sound Emission | 60 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 8 - 80% RH |
