Expand your view and your productivity with this 60.5 cm (23.8-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek monitor makes hybrid work easy and complete via a crisp, smooth screen and simple design, so you can do more everyday.
Product Description | HP P24v G5 - P-Series - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Power Consumption (On mode) | 17.9 W | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.27 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 8000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey with overdrive) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating, Haze 25% | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black stand, black head | Dimensions (WxDxH) - with stand | 53.89 cm x 18.05 cm x 39.78 cm | Weight | 3.57 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified | Compliant Standards | CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, ICES, CEC, KC, ERP, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, low halogen, TUV Rheinland Flicker Free Certification, Energy-using Products (EuP) Lot 5, UAE, Australian-New Zealand MEPS, Vietnam MEPS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | VA |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 55.6 - 90.8 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | Edge-lit LED |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese |
Features | HDCP, On-screen Digital Controls, Low Blue Light Mode, 3-sided micro-edge, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth |
Dimensions (WxDxH) | 53.89 cm x 18.05 cm x 39.78 cm - with stand |
Weight | 3.57 kg |
Connectivity | |
Interfaces | HDMI (HDCP) , VGA |
Mechanical | |
Tilt Angle | -5/+23 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant |
Cables Included | 1 x HDMI cable - 1.8 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17.9 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption (Max) | 30 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | HP Display Center, HP Display Manager |
OS Required | Microsoft Windows 7, Windows 8, Windows 10, Windows 11 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.89 cm - depth: 18.05 cm - height: 39.7 cm - weight: 3.57 kg , Without stand - width: 53.89 cm - depth: 5.143 cm - height: 32.36 cm - weight: 3.17 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 59.5 cm |
Shipping Depth | 12.4 cm |
Shipping Height | 39.1 cm |
Shipping Weight | 5.49 kg |
Sustainability Information | |
TCO Certified | TCO Certified Edge Displays, TCO Certified Displays 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% RH (non-condensing) |
