Be productive in and out of the office and help shield your tablet from bumps with the HP Pro 8 Travel Keyboard, a thin and light keyboard and wraparound case in one.
Product Description | HP Travel - keyboard and folio case - US | Device Type | Keyboard and folio case | Interface | Dock | Localization and Layout | US | Keys Qty | 56 | Colour | Graphite case | Case Material | Polyurethane | Dimensions (WxDxH) | 21.8 cm x 14.88 cm x 0.495 cm | Weight | 713 g | Designed For | Pro Slate 8 |
General | |
Interface | Dock |
Input Device | |
Keys Qty | 56 |
Width | 21.8 cm |
Depth | 14.88 cm |
Height | 0.495 cm |
Weight | 713 g |
Carrying Case | |
Colour | Graphite |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Compatibility Information | |
Designed For | HP Pro Slate 8 |
