ITEM | QTY | PRICE |
Belkin BOOST UP CHARGE 10000 mAh 18 W...
4 | £202.00 |
The versatile HP Pro x2 design strikes the right balance of mobility, durability, and security in a device that is designed to last. Ideal for challenging environments, this versatile detachable PC lets you work the way you want.
Product Description | HP Pro x2 612 G2 - 12" - Intel Core i5 - 7Y54 - 4 GB RAM - 256 GB SSD | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (7th Gen) - 7Y54 / 1.2 GHz, up to 3.2 GHz / 4 MB Cache | Memory | 4 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD - SED, TCG Opal Encryption 2, TLC | Display | 12" LED backlight touchscreen 1920 x 1280 / WUXGA+ - 192 ppi | Graphics | Intel HD Graphics 615 | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | 4-cell - up to 10 hours | Features | Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor | Security | Trusted Platform Module (TPM 2.0) Security Chip, smart card reader | Dimensions (WxDxH) - tablet | 30 cm x 21.93 cm x 0.91 cm | Weight | 850 g | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7Y54 / 1.2 GHz |
Max Turbo Speed | 3.2 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 2280 SATA 6Gb/s - Self-Encrypting Drive, TCG Opal Encryption 2, triple-level cell (TLC) |
Display | |
Type | 12" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1280 (WUXGA+) |
Widescreen | Yes |
Pixel Density (ppi) | 192 |
Image Brightness | 340 cd/m² |
Features | Ultra Slim Design, Corning Gorilla glass 4, WUXGA+ ultra wide-viewing angle (UWVA) BrightView eDP +PSR |
Audio & Video | |
Graphics Processor | Intel HD Graphics 615 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1080p |
Resolution | 8 Megapixel (rear), 5 Megapixel (front) |
Frame Rate | 30 frames per second |
Sound | Stereo speakers, two microphones |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2) |
Compliant Standards | IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell lithium polymer |
Capacity | 41.58 Wh |
Run Time | Up to 10 hours |
AC Adapter | |
Output | 65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V |
Connections & Expansion | |
Slots | 1 x Micro-SIM card (1 free) |
Interfaces Details | USB-C 3.1 (docking and charging) , USB 3.0 , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Miscellaneous | |
Integrated Options | Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor |
Features | BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | Keyboard |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 850 g |
Dimensions (WxDxH) / Weight Details | 30 cm x 21.93 cm x 0.91 cm / 850 g - tablet |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Limited warranty - battery - 1 year |
Get more from your purchase from one of our essential accessories
