The thin, light, tough design of the HP ProBook 440 gives mobile professionals powerful tools to stay productive on the go. Equipped for productivity, this ProBook delivers the performance and security features essential for today's mobile workforce.
Designed for mobility
Travel in style with the thin and light 35.56 cm (14-inch) diagonal HP ProBook 440 with a new asteroid silver design. Confidently take on the day with a PC that's designed to pass MIL-STD 810G testing, built with an aluminum reinforced keyboard deck.
Powerful processing
Power through projects with 7th Gen Intel Core i3/i5/i7 processors and optional NVIDIA GeForce discrete graphics.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP BIOSphere as well as the embedded TPM and an optional fingerprint reader.
Immersive experience
Enjoy the rich user experience of the HP ProBook 440 with long battery life and features designed to create a stunning visual and audio experience with HP Audio Boost, HP Noise Cancellation, and options like an FHD display, and an HD touch display.
Product Description | HP ProBook 440 G4 Notebook - 14" - Intel Core i5 - 7200U - 4 GB RAM - 500 GB HDD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 500 GB HDD / 7200 rpm | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Input Device | ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell - up to 15.5 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) | 34.32 cm x 23.9 cm x 2.03 cm | Weight | 1.64 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA 6Gb/s / 7200 rpm |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Features | Slim Design, HD standard-viewing angle (SVA) anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Video Resolutions | 1280 x 720 |
Camera Features | 720p HD movie recording |
Sound | Stereo speakers, two microphones |
Codec | Conexant CX7700 |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Spill-resistant, ClickPad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Remote Management Protocol | SNMP 2 |
Features | Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 15.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | USB 3.0 , USB 2.0 (power only) , USB-C , HDMI , Headphone/microphone combo jack , LAN , VGA |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Features | HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, Preboot Security, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.64 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
