Built for productivity, the HP ProBook 450 delivers the performance and security features essential for today's workforce. The sleek and tough design provides professionals a flexible platform to stay productive in or out of the office.
Product Description | HP ProBook 450 G3 Notebook - 15.6" - Intel Core i3 - 6100U - 4 GB RAM - 500 GB HDD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i3 (6th Gen) - 6100U / 2.3 GHz / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 500 GB HDD / 7200 rpm | Optical Drive | DVD | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 520 | Keyboard | UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM 1.2) Security Chip | Dimensions (WxDxH) | 37.8 cm x 26.43 cm x 2.48 cm | Weight | 2.07 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i3 (6th Gen) 6100U / 2.3 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA 6Gb/s / 7200 rpm |
Optical Drive | DVD-ROM removable - tray |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | HD standard-viewing angle (SVA) eDP anti-glare |
Keyboard Name | HP Premium |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 3165 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Remote Management Protocol | SNMP 2 |
Features | Miracast, Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 44 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 19.5 V |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , 2 x USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , VGA |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Drivers & Utilities, CyberLink Power2Go, HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, CyberLink Youcam, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), Absolute Persistence, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Caller Dashboard |
Miscellaneous | |
Features | HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, HP Drive Encryption, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, Pre-boot Authentication |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.07 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
