Get the optimal from your investment with configuration, that supports today’s technology and legacy devices. The HP ProBook 640 is equipped with the improved security and productivity features and is compatible with your existing IT investments.
Blend new features with proven technology
Simplify deployment of new PCs with the HP ProBook 640 that easily integrates into your current IT structure. Optional optical drives and legacy ports like a standard VGA port and RJ-45 connection help reduce the costs of upgrading your PCs.
Mobilize your workforce
Give your deskbound workforce the benefits of mobility without sacrificing performance or breaking the budget with 7th Gen Intel® Core™ i3/i5/i7 processors, expansive DDR4 memory, and peripherals like the HP UltraSlim dock.
HP exclusive security and manageability
Help prevent data breaches and downtime with HP BIOSphere Gen3 and self-encrypting. Simplify management with HP configuration across the globe, available in more than 180 countries where HP conducts business.
Collaborate on the go
Business doesn’t stop when you are away from the office. HP Noise Cancellation Software, HP Audio Boost, Skype for business, and a 720p webcam are collaboration tools that help you communicate clearly with colleagues.
Product Description | HP ProBook 640 G3 Notebook - 14" - Intel Core i5 - 7200U - 4 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 256 GB SSD - HP Z Turbo Drive G2, NVMe, TLC | Optical Drive | DVD-Writer | Display | 14" WLED 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 34 cm x 23.7 cm x 2.7 cm | Weight | 1.95 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe - HP Z Turbo Drive G2, NVM Express (NVMe), triple-level cell (TLC) |
Optical Drive | DVD-Writer - tray |
Display | |
Type | 14" |
LCD Backlight Technology | WLED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare |
Keyboard Name | HP Premium |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Volume control, spill-resistant |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Compliant Standards | IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 48 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | USB-C , USB 3.0 , USB 3.0 (charging) , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA |
Software | |
Software Included | CyberLink Power2Go, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Workwise, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3 |
Miscellaneous | |
Dockable | Yes |
Features | DriveLock, HP 3D DriveGuard, Automatic DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS, WEEE, Common Criteria EAL4+ |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.95 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
