Take on the demands of your growing business with the ultra-slim HP ProBook x360 440. Get the power, security, and durability you need in a versatile 360° design that adapts to the way you work.
Product Description | HP ProBook x360 440 G1 Notebook - 14" - Intel Core i5 8250U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook - flip design | Operating System | Win 10 Home 64-bit - English | Processor | Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD - NVMe, HP Value | Display | 14" WLED touchscreen 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 | Input Device | ClickPad | Keyboard | UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell - up to 13 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) | 33 cm x 23.2 cm x 1.99 cm | Weight | 1.72 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Home 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8250U / 1.6 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2400 MHz / PC4-19200 |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Value |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | WLED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 220 cd/m² |
Colour Gamut | 67% sRGB |
Features | Slim Design, Full HD ultra wide-viewing angle (UWVA) BrightView eDP |
Keyboard Name | HP Premium |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - HD |
Video Resolutions | 720p |
Camera Features | IR camera |
Sound | Stereo speakers, dual array microphone |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Spill-resistant, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Features | Miracast, dual stream (2x2) |
Compliant Standards | IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 13 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces | USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 3.0 (charging) , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, SDXC Card) |
Miscellaneous | |
Features | Automatic DriveLock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, ICCP |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.72 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
