Designed to fit the modern workspace, the small, reliable, and secure HP ProDesk 400 is a powerful PC with performance that's scalable to grow with the business.
Product Description | HP ProDesk 400 G4 - SFF - Core i3 6100 3.7 GHz - 4 GB - SSD 128 GB - UK | Type | Personal computer - small form factor | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core) | Processor Main Features | Hyper-Threading Technology, Intel Smart Cache | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 128 GB - SATA 6Gb/s | Optical Storage | DVD-Writer | Graphics Controller | Intel HD Graphics 530 Dynamic Video Memory Technology | Audio Output | Stereo | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Home 64-bit Edition | Software Included | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications | Dimensions (WxDxH) | 27 cm x 29.6 cm x 9.5 cm | Weight | 4.6 kg | Manufacturer Warranty | Limited warranty - parts and labour - 1 year - on-site |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i3 (6th Gen) 6100 |
Clock Speed | 3.7 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | Intel H270 |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2400 MHz |
Memory Specification Compliance | PC4-19200 |
Form Factor | DIMM 288-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 128 GB |
Interface Type | SATA 6Gb/s |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 530 Dynamic Video Memory Technology |
Video Interfaces | VGA, DisplayPort |
HDCP Compatible | Yes |
Max Monitors Supported | 3 |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Interface (Bus) Type | PCI Express 1.1 x1 |
Ethernet Controller | Realtek RTL8111HSH |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol | SNMP 2 |
Features | Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" |
Slots | 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile |
Interfaces | 4 x USB 2.0 (two of them with wake functionality) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
80 PLUS Certification | 80 PLUS Bronze |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Home 64-bit Edition English |
Software | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year - on-site |
Dimensions & Weight | |
Width | 27 cm |
Depth | 29.6 cm |
Height | 9.5 cm |
Weight | 4.6 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
