With a modern, new look and a small size, the HP t530 has raised the stakes for thin client design. Multiple deployment options allow this thin client to fit into any workspace.
Product Description | HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - flash 8 GB | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-215JJ 1.5 GHz (, up to 2 GHz, (Dual-Core) | Processor Main Features | AMD Turbo CORE Technology | Cache Memory | 1 MB L2 Cache | Cache Per Processor | 1 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC | Hard Drive | Flash 8 GB - M.2 - multi-level cell (MLC) | Optical Storage | No optical drive | Graphics Controller | AMD Radeon R2E | Networking | 1GbE | Power | AC 120/230 V (50/60 Hz) | OS Provided | HP ThinPro | Dimensions (WxDxH) | 3.5 cm x 20 cm x 20 cm | Weight | 962.8 g | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Product Form Factor | Tower |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | AMD GX-215JJ |
Clock Speed | 1.5 GHz |
Max Turbo Speed | 2 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L2 Cache - 1 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 1866 MHz |
Rated Memory Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 1 (Total) / 0 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | Flash - M.2 |
Capacity | 1 x 8 GB |
Features | Multi-level cell (MLC) |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R2E |
Video Interfaces | DisplayPort |
Max Monitors Supported | 2 |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), DHCP support, PXE support |
Compliant Standards | IEEE 802.1x |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card |
Interfaces | 1 x USB 3.1 Gen 1 (1 in front) , 1 x USB-C Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45 |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, ICES, MEPS, ERP, CECP, EMI/EMS Class B, low halogen |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 45 Watt |
Operating System / Software | |
OS Certified | HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IoT Enterprise |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 3.5 cm |
Depth | 20 cm |
Height | 20 cm |
Weight | 962.8 g |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
