Fast, affordable, and designed to handle everything from simple colour jobs to complex workflows. Quickly and reliably digitise larger projects with scan speeds up to 24 ppm/48 ipm and a 50-page ADF. Recommended for 2,000 pages per day.
Small size. Fast scans. Same reliable results.
Produce scans at up to 24 ppm/48 ipm with two-sided scanning that captures both sides at once.
Optimise workflows with one-touch scanning
Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.
Capture business documents like a pro
Define scan profiles for common document types, and scan to multiple destinations with HP Scan software.
Product Description | HP Scanjet Pro 2000 s1 Sheet-feed - document scanner - desktop - USB 2.0 | Device Type | Document scanner - desktop | Interface Type | USB 2.0 | Max Supported Document Size | 216 x 3100 mm | Localisation | English, German, French, Italian, Spanish / Europe | Input Type | Colour | Grayscale / Color Depth | 48-bit colour | Optical Resolution | 600 dpi x 600 dpi | Max Document Scan Speed | 24 ppm (mono) | Max Document Size | 216 mm x 3100 mm | Automatic Duplexing | Yes | Document Feeder Type | Automatic | Document Storage Capacity | 50 sheets | Duty Cycle | 2000 scans per day | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Scanner | |
Colour Depth | 48-bit colour |
Max Document Scan Speed B/W | 24 ppm |
Scanner Speed Details | 24 ppm , 48 ipm , 6.9 sec/scan - colour - 10x15cm - 200 dpi , 9.13 sec/scan - A4 - 300 dpi |
Compliant Standards | TWAIN, ISIS, WIA |
Media Handling | |
Supported Document Size Details | ADF |
Expansion / Connectivity | |
Interfaces | USB 2.0 - Type B |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight (Shipping) | |
Shipping Width | 39.7 cm |
Shipping Depth | 24.8 cm |
Shipping Height | 24.2 cm |
Shipping Weight | 4 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
