The HP Dual Serial USB Thermal Receipt Printer is the ideal single station thermal printer for retail environments. Its fast print speed, compact size and long life expectancy mean optimal performance for retail point of sale applications. It features a large 90 mm paper roll capacity. It also works seamlessly with the HP cash drawer.
Product Description | HP Dual Serial USB Thermal Receipt Printer - receipt printer - B/W - direct thermal | Printer Type | Receipt printer - direct thermal - B/W | Weight | 1.34 kg | Max Resolution (B&W) | 203 dpi | Cutter | Yes | Interface | USB, serial | RAM Installed (Max) | 512 KB | Flash Memory Installed (Max) | 4 MB | Barcodes | Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, PDF417 | System Requirements | Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Embedded for Point of Service, Microsoft Windows Vista Business (32/64 bits) | Enclosure Colour | Carbonite | Dimensions (WxDxH) | 14.4 cm x 18.4 cm x 13.4 cm |
General | |
Printer Type | Receipt printer - direct thermal - monochrome |
Printer | |
Built-in Devices | Cutter |
Connectivity Technology | Wired |
Cutter | Yes |
RAM | |
Flash Memory | |
Flash Memory | 4 MB |
Expansion / Connectivity | |
Connections | 1 x USB / serial RS-232: |
Miscellaneous | |
Cables Included | 1 x USB cable |
Compliant Standards | EN 60950, GS, ICES-003, SABS, UL 1950, VCCI Class A ITE, CSA 22.2 No. 950, WHQL, MITI, FCC, RoHS, WEEE |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Embedded for Point of Service, Microsoft Windows Vista Business (32/64 bits) |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Dimensions & Weight | |
Width | 14.4 cm |
Depth | 18.4 cm |
Height | 13.4 cm |
Weight | 1.34 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 25 cm |
Depth (Shipping) | 20 cm |
Height (Shipping) | 20 cm |
