Hardware compatibility
HP Elite Slice and HP Elite Slice for Meetings
Convert your HP Elite Slice into a speakerphone or a multimedia player with the HP Audio Module. Meetings, video, and music come to life with impeccable sound and clarity, custom-tuned in collaboration with audio experts at Bang & Olufsen.
Pitch perfect
Experience 360o immersive stereo sound and collaborate from across the room with bi-directional HP Noise Cancellation, a dual-microphone array with far-field 5-meter range, three speakers, and HP Audio Boost.
No cabling or screws required
Snap the Module beneath your HP Elite Slice with a sturdy USB-type connection that provides a simple and clean solution with no messy cables.
Complete, compact collaboration
Focus on your meeting instead of unsightly cables when you combine your HP Elite Slice with the HP Audio Module and the touch-enabled HP Collaboration Cover—each perfect piece designed to fit the other.
Lock it down
Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your Module and HP Elite Slice together with one cable lock.
Mix and match
Create a unique solution for each of your employees when you use the HP Audio Module stacked with your HP Elite Slice and any of the other HP Elite Slice accessories.
Product Description | HP Audio Module - speaker - for PC | Product Type | Speaker - for PC | Features | 2 microphones | System Components | 3 speakers | Speaker Type | Active | Amplifier | Integrated | Speaker System Details | 2 | Speaker Details | Speaker - stereo - active | Colour | Black sparkle | Dimensions (WxDxH) | 16.5 cm x 16.5 cm x 2.45 cm | Weight | 404 g | Manufacturer Warranty | 1-year warranty | Designed For | OMEN X by HP 900; Elite Slice, Slice for Meeting Rooms, Slice G2; ENVY 27, 750; ENVY Curved 34; Pavilion 24, 27 |
General | |
Enclosure Colour | Black sparkle |
Speaker System | |
Speaker System Details | |
Speakers Included | 2 - wired |
Dimensions & Weight | |
Width | 16.5 cm |
Depth | 16.5 cm |
Height | 2.45 cm |
Weight | 404 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
Designed For | OMEN X by HP 900-000t , HP Elite Slice, Slice for Meeting Rooms, Slice G2 with Intel Unite , HP ENVY 27-b010, 750-411, 750-424, 750-471na, 750-478nz, 750-537cb, 750-545xt, 750-555qe, 750-567cb , HP ENVY Curved 34-a001la, 34-a090nb, 34-a090nf, 34-a090nl, 34-a090no, 34-a090nz, 34-a150, 34-b000ng, 34-b004la, 34-b010nl, 34-b013nf, 34-b071ns, 34-b080nl , HP Pavilion 24-b010, 24-b017c, 27-a002la, 27-a021, 27-a031 |
