Optimized for desktop virtualization and cloud-based applications, the intuitive HP t430 Thin Client is easy for end users to understand and simple for IT administrators to maintain.
Product Description | HP t430 - DTS - Celeron N4000 1.1 GHz - 4 GB - flash 16 GB | Type | Thin client - desktop slimline | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Celeron N4000 / 1.1 GHz (2.6 GHz) (Dual-Core) | Processor Main Features | Intel Burst Technology | Cache Memory | 4 MB | Cache Per Processor | 4 MB | RAM | 4 GB DDR4 SDRAM | Hard Drive | Flash 16 GB - eMMC | Optical Storage | No optical drive | Graphics Controller | Intel UHD Graphics 600 | Networking | GigE, Bluetooth, 802.11a, 802.11b/g/n, 802.11ac | Power | AC 120/230 V (50/60 Hz) | OS Provided | HP Smart Zero Core | Dimensions (WxDxH) | 13.5 cm x 13.5 cm x 3.2 cm | Weight | 410 g | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Product Form Factor | Desktop slimline |
Processor / Chipset | |
CPU | Intel Celeron N4000 |
Clock Speed | 1.1 GHz |
Max Turbo Speed | 2.6 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 4 MB |
RAM | |
Installed Size | 4 GB |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Configuration Features | Provided memory is soldered |
Hard Drive | |
Type | Flash - eMMC |
Capacity | 1 x 16 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 600 |
Video Interfaces | HDMI, DisplayPort |
Max Monitors Supported | 2 |
Networking | |
Interface (Bus) Type | M.2 Card |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Wireless-AC 9260 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Expansion / Connectivity | |
Interfaces | 1 x DisplayPort/USB-C 3.1 Gen 1 (PowerShare) , 3 x USB - Type A , 1 x DisplayPort output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm |
Compliant Standards | FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, AS/NZS, ERP, CECP, VCCI Class B, CISPR Class B, EN, CNS |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 45 Watt |
Operating System / Software | |
OS Provided | HP Smart Zero Core English |
Software | Citrix ICA, Microsoft RDP, HP Easy Tools, HP Device Manager, LogOn Manager, Citrix Receiver, HP TeemTalk Terminal Emulator, VMware Horizon View, FreeRDP, HP Smart Zero Client Services |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 13.5 cm |
Depth | 13.5 cm |
Height | 3.2 cm |
Weight | 410 g |
Dimensions & Weight (Shipping) | |
Shipping Weight | 1.27 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
