Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
Product Description | HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - flash 32 GB - UK | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-215JJ 1.5 GHz (, up to 2 GHz, (Dual-Core) | Processor Main Features | AMD Turbo CORE Technology | Cache Memory | 1 MB L2 Cache | Cache Per Processor | 1 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC | Hard Drive | Flash 32 GB - M.2 | Optical Storage | No optical drive | Graphics Controller | AMD Radeon R2E | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 IoT Enterprise 64-bit Edition | Software Included | Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP Remote Graphics Software, Microsoft Windows Media Player 12, HP Device Manager, LogOn Manager, Citrix Receiver, Citrix HDX, HP Velocity, Microsoft RemoteFX, Unified Write Filter, Microsoft Internet Explorer 11, HP ThinUpdate, HP Easy Shell, Amazon WorkSpaces, Microsoft SCCM/EDM-agent, VMware Horizon Clients | Dimensions (WxDxH) | 3.5 cm x 20 cm x 20 cm | Weight | 962.8 g | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Product Form Factor | Tower |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | AMD GX-215JJ |
Clock Speed | 1.5 GHz |
Max Turbo Speed | 2 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L2 Cache - 1 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 1866 MHz |
Rated Memory Speed | 1866 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 1 (Total) / 0 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | Flash - M.2 |
Capacity | 1 x 32 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R2E |
Video Interfaces | DisplayPort |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), DHCP support, PXE support |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x M.2 Card |
Interfaces | 3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 45 Watt |
Operating System / Software | |
OS Provided | Windows 10 IoT Enterprise 64-bit Edition English |
Software | Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP Remote Graphics Software, Microsoft Windows Media Player 12, HP Device Manager, LogOn Manager, Citrix Receiver, Citrix HDX, HP Velocity, Microsoft RemoteFX, Unified Write Filter, Microsoft Internet Explorer 11, HP ThinUpdate, HP Easy Shell, Amazon WorkSpaces, Microsoft SCCM/EDM-agent, VMware Horizon Clients |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 3.5 cm |
Depth | 20 cm |
Height | 20 cm |
Weight | 962.8 g |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
