Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
Product Description | HP Flexible t620 - tower - GX-217GA 1.65 GHz - 4 GB - SSD 16 GB - UK - TAA Compliant | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-217GA 1.65 GHz (Dual-Core) | Cache Memory | 1 MB L2 Cache | Cache Per Processor | 1 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800 | Hard Drive | SSD 16 GB - SATA - mSATA | Optical Storage | No optical drive | Graphics Controller | AMD Radeon HD 8280E | Audio Output | Stereo - integrated | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Microsoft Windows Embedded Standard 7P 64-bit | Software Included | Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, Microsoft Windows Media Player 12, File Based Write Filter, Enhanced Write Filter, HP Device Manager, LogOn Manager, Microsoft Internet Explorer 10, Citrix HDX, HP Velocity, Microsoft RemoteFX, HP Cloud Connection Manager, VMware Horizon View 5.4, VMware PCoIP, Citrix Receiver 4.1, Citrix XenDesktop, HP Remote Graphics Software 7, HP ThinShell 2.1, Microsoft Remote Desktop Protocol (RDP) Client 8.1 | Dimensions (WxDxH) | 4 cm x 22 cm x 24 cm | Weight | 1.36 kg | Pricing Type | Promo | TAA Compliant | Yes | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Product Form Factor | Tower |
Processor / Chipset | |
CPU | AMD GX-217GA |
Clock Speed | 1.65 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L2 Cache - 1 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR3L SDRAM |
Effective Memory Speed | 1600 MHz |
Rated Memory Speed | 1600 MHz |
Memory Specification Compliance | PC3-12800 |
Form Factor | SO-DIMM 204-pin |
Slots | 2 (Total) |
Features | Low-voltage |
Hard Drive | |
Type | SSD - mSATA |
Capacity | 1 x 16 GB |
Interface Type | SATA |
Features | Multi-level cell (MLC) |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Type | Integrated |
Graphics Processor | AMD Radeon HD 8280E |
Video Interfaces | VGA, DisplayPort |
Audio Output | |
Type | Integrated |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Type | Integrated |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), DHCP support, PXE support |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x M.2 Card |
Interfaces | 6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x VGA |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Operating System / Software | |
OS Provided | Microsoft Windows Embedded Standard 7P 64-bit English |
OS Certified | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012 |
Software | Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, Microsoft Windows Media Player 12, File Based Write Filter, Enhanced Write Filter, HP Device Manager, LogOn Manager, Microsoft Internet Explorer 10, Citrix HDX, HP Velocity, Microsoft RemoteFX, HP Cloud Connection Manager, VMware Horizon View 5.4, VMware PCoIP, Citrix Receiver 4.1, Citrix XenDesktop, HP Remote Graphics Software 7, HP ThinShell 2.1, Microsoft Remote Desktop Protocol (RDP) Client 8.1 |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 4 cm |
Depth | 22 cm |
Height | 24 cm |
Weight | 1.36 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
