Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
Product Description | HP Flexible t620 - tower - GX-217GA 1.65 GHz - 4 GB - SSD 8 GB - UK - TAA Compliant | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-217GA 1.65 GHz (Dual-Core) | Cache Memory | 1 MB L2 Cache | Cache Per Processor | 1 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800 | Hard Drive | SSD 8 GB - SATA - M.2 | Optical Storage | No optical drive | Graphics Controller | AMD Radeon HD 8280E | Audio Output | Stereo - integrated | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | HP ThinPro 32-bit | Software Included | Citrix ICA, Microsoft RDP, HP ThinState Tools, HP Connection Manager, HP Easy Tools, HP Device Manager, Citrix HDX, HP Velocity, Citrix Receiver 12.1.5, FreeRDP 1.0, Microsoft RemoteFX, HP Cloud Connection Manager, VMware Horizon View 2.1, HP TeemTalk Terminal Emulator 7.3.3, Mozilla Firefox 19, Citrix XenDesktop | Dimensions (WxDxH) | 4 cm x 22 cm x 24 cm | Weight | 1.36 kg | TAA Compliant | Yes | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years |
General | |
Type | Thin client |
Recommended Use | Small business, corporate business |
Product Form Factor | Tower |
Processor / Chipset | |
CPU | AMD GX-217GA |
Clock Speed | 1.65 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L2 Cache - 1 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR3L SDRAM |
Effective Memory Speed | 1600 MHz |
Rated Memory Speed | 1600 MHz |
Memory Specification Compliance | PC3-12800 |
Form Factor | SO-DIMM 204-pin |
Slots | 2 (Total) |
Features | Low-voltage |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 8 GB |
Interface Type | SATA |
Features | Multi-level cell (MLC) |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Type | Integrated |
Graphics Processor | AMD Radeon HD 8280E |
Video Interfaces | DisplayPort |
Audio Output | |
Type | Integrated |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Standard Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Type | Integrated |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), DHCP support, PXE support |
Expansion / Connectivity | |
Slots | 1 (total) / 1 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 0 (free) x M.2 Card |
Interfaces | 6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm |
Compliant Standards | FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Operating System / Software | |
OS Provided | HP ThinPro 32-bit English |
OS Certified | Microsoft Windows Server 2003, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012 |
Software | Citrix ICA, Microsoft RDP, HP ThinState Tools, HP Connection Manager, HP Easy Tools, HP Device Manager, Citrix HDX, HP Velocity, Citrix Receiver 12.1.5, FreeRDP 1.0, Microsoft RemoteFX, HP Cloud Connection Manager, VMware Horizon View 2.1, HP TeemTalk Terminal Emulator 7.3.3, Mozilla Firefox 19, Citrix XenDesktop |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 4 cm |
Depth | 22 cm |
Height | 24 cm |
Weight | 1.36 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
