Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Product Description | HP t630 - tower - GX-420GI 2 GHz - 4 GB - flash 32 GB - UK - TAA Compliant | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-420GI 2 GHz (, up to 2.2 GHz, (Quad-Core) | Processor Main Features | AMD Turbo CORE Technology | Cache Memory | 2 MB L2 Cache | Cache Per Processor | 2 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900 | Hard Drive | Flash 32 GB - M.2 | Optical Storage | No optical drive | Graphics Controller | AMD Radeon R7E | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Microsoft Windows Embedded Standard 7E 32-bit (downgrade from Windows 10 IoT Enterprise) + Windows 10 IoT Enterprise Licence | Dimensions (WxDxH) | 12 cm x 22 cm x 25.1 cm | Weight | 1.52 kg | TAA Compliant | Yes | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Product Form Factor | Tower |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | AMD GX-420GI |
Clock Speed | 2 GHz |
Max Turbo Speed | 2.2 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L2 Cache - 2 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 1866 MHz |
Rated Memory Speed | 1866 MHz |
Memory Specification Compliance | PC4-14900 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | Flash - M.2 |
Capacity | 1 x 32 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R7E |
Video Interfaces | DisplayPort |
Max Monitors Supported | 2 |
Input Device | |
Type | Keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), PXE support |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 1 (free) x M.2 Card - 2242 |
Interfaces | 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 (2 front, 2 rear) , 3 x USB 3.0 (2 front, 1 internal) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x audio line-out/line-in |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Operating System / Software | |
OS Provided | Microsoft Windows Embedded Standard 7E 32-bit (available through downgrade rights from Windows 10 IoT Enterprise for Thin Clients 64-bit) + Windows 10 IoT Enterprise Licence - English |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 12 cm |
Depth | 22 cm |
Height | 25.1 cm |
Weight | 1.52 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 4.1 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
