Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Product Description | HP t630 - tower - GX-420GI 2 GHz - 4 GB - flash 8 GB - TAA Compliant | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-420GI 2 GHz (, up to 2.2 GHz, (Quad-Core) | Processor Main Features | AMD Turbo CORE Technology | Cache Memory | 2 MB L2 Cache | Cache Per Processor | 2 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900 | Hard Drive | Flash 8 GB - M.2 | Optical Storage | No optical drive | Graphics Controller | AMD Radeon R7E | Networking | 1GbE | Power | AC 120/230 V (50/60 Hz) | OS Provided | HP ThinPro | Software Included | Citrix ICA, Microsoft RDP, HP Easy Tools, HP Device Manager, LogOn Manager, Citrix Receiver, HP TeemTalk Terminal Emulator, VMware Horizon View, Citrix HDX, HP Velocity, HP Smart Zero Client, FreeRDP, Microsoft RemoteFX, Mozilla Firefox 36 | Dimensions (WxDxH) | 12 cm x 22 cm x 25.1 cm | Weight | 1.52 kg | TAA Compliant | Yes | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Product Form Factor | Tower |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | AMD GX-420GI |
Clock Speed | 2 GHz |
Max Turbo Speed | 2.2 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L2 Cache - 2 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 1866 MHz |
Rated Memory Speed | 1866 MHz |
Memory Specification Compliance | PC4-14900 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | Flash - M.2 |
Capacity | 1 x 8 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R7E |
Video Interfaces | DisplayPort |
Max Monitors Supported | 2 |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), PXE support |
Expansion / Connectivity | |
Slots | 1 M.2 Card - 2280 , 1 M.2 Card - 2242 |
Interfaces | 4 x USB 2.0 (2 front, 2 rear) , 3 x USB 3.0 (2 front, 1 internal) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x serial , 1 x headphones/microphone (1 in front) , 1 x audio line-out/line-in |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Operating System / Software | |
OS Provided | HP ThinPro English |
Software | Citrix ICA, Microsoft RDP, HP Easy Tools, HP Device Manager, LogOn Manager, Citrix Receiver, HP TeemTalk Terminal Emulator, VMware Horizon View, Citrix HDX, HP Velocity, HP Smart Zero Client, FreeRDP, Microsoft RemoteFX, Mozilla Firefox 36 |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 12 cm |
Depth | 22 cm |
Height | 25.1 cm |
Weight | 1.52 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 4.1 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
