Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
Product Description | HP t730 - tower - R-series Embedded RX427BB 2.7 GHz - 8 GB - flash 32 GB - UK | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD R-series Embedded RX427BB / 2.7 GHz (, up to 3.6 GHz, (Quad-Core) | Cache Memory | 4 MB L2 Cache | Cache Per Processor | 4 MB | RAM | 8 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3L-12800 | Hard Drive | Flash 32 GB - M.2 | Optical Storage | No optical drive | Graphics Controller | AMD Radeon HD 9000 | Networking | 1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 IoT Enterprise | Software Included | HP Easy Tools, HP Device Manager, HP Velocity, HP ThinUpdate, HP True Graphics, HP Easy Shell | Dimensions (WxDxH) | 6.7 cm x 22.1 cm x 24 cm | Weight | 1.8 kg | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Thin client |
Product Form Factor | Tower |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | AMD R-series Embedded RX427BB |
Clock Speed | 2.7 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | L2 Cache - 4 MB |
RAM | |
Installed Size | 8 GB / 16 GB (max) |
Technology | DDR3L SDRAM |
Effective Memory Speed | 1600 MHz |
Rated Memory Speed | 1600 MHz |
Memory Specification Compliance | PC3L-12800 |
Form Factor | SO-DIMM 204-pin |
Slots | 2 (Total) / 0 (empty) |
Features | Dual channel memory architecture |
Configuration Features | 2 x 4 GB |
Hard Drive | |
Type | Flash - M.2 |
Capacity | 1 x 32 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon HD 9000 |
Video Interfaces | DisplayPort |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Mouse Name | HP Hardened |
Interface | USB |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Features | Wake on LAN (WoL), PXE support |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 (x8 mode) |
Interfaces | 6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 4 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-in , 1 x audio line-out |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 85 Watt |
Operating System / Software | |
OS Provided | Windows 10 IoT Enterprise English |
Software | HP Easy Tools, HP Device Manager, HP Velocity, HP ThinUpdate, HP True Graphics, HP Easy Shell |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 6.7 cm |
Depth | 22.1 cm |
Height | 24 cm |
Weight | 1.8 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 4.5 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
