The HP PUSB Thermal Receipt Printer is designed for retail environments with its durable design and print performance. Its compact size also makes it perfect for space-constrained locations.
Product Description | HP Single Station Thermal Receipt Printer - receipt printer - two-colour (monochrome) - direct thermal | Printer Type | Receipt printer - direct thermal - two-colour (monochrome) | Weight | 1.34 kg | Max Media Size | Roll (0.8 cm) | Print Speed | Up to 74 lines/sec - monochrome , Up to 44 lines/sec - two-colour | Max Resolution (B&W) | 203 dpi | Interface | PoweredUSB | RAM Installed (Max) | 512 KB | Flash Memory Installed (Max) | 4 MB | Media Type | Thermal paper | System Requirements | Microsoft Windows XP Professional, Microsoft Windows Embedded for Point of Service, Microsoft Windows Vista Business | Dimensions (WxDxH) | 13.4 cm x 18.4 cm x 14.4 cm |
General | |
Printer | |
Connectivity Technology | Wired |
Columns | 56, 44 |
RAM | |
Flash Memory | |
Flash Memory | 4 MB |
Media Handling | |
Media Sizes | Roll (0.8 cm) |
Media Feeders | 1 x manual - Roll (0.8 cm) |
Expansion / Connectivity | |
Connections | 1 x PoweredUSB |
Miscellaneous | |
Compliant Standards | FCC Class B certified, VCCI, C-Tick, EN 60950, ICES-003, UL 1950, CSA 22.2 No. 950, WHQL, MITI, CCC, MIC, FCC, RoHS, WEEE |
Software / System Requirements | |
OS Required | Microsoft Windows XP Professional, Microsoft Windows Embedded for Point of Service, Microsoft Windows Vista Business |
Dimensions & Weight | |
Width | 13.4 cm |
Depth | 18.4 cm |
Height | 14.4 cm |
Weight | 1.34 kg |
