Top-of-the-line power to fuel those who reimagine our world. When you need a workstation with the capability to run complex simulations, handle advanced Machine Learning algorithms and process huge amounts of data, the HP Z8 doesn't disappoint.
Product Description | HP Workstation Z8 G4 - tower - Xeon Silver 4108 1.8 GHz - vPro - 32 GB - HDD 1 TB | Type | Workstation - tower | Platform Technology | Intel vPro Platform | Height (Rack Units) | 5U | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Xeon Silver 4108 / 1.8 GHz (, up to 3 GHz, (8-core) | Processor Socket | FCLGA3647 Socket | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2 | Cache Memory | 11 MB L3 Cache | Cache Per Processor | 11 MB | RAM | 32 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC - PC4-21333 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | HDD 1 TB - SATA 6Gb/s - 7200 rpm | Optical Storage | No optical drive | Graphics Controller | No graphics | Audio Output | Stereo | Networking | 1GbE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro for Workstations Plus 64-bit Edition | Dimensions (WxDxH) | 21.59 cm x 55.12 cm x 44.45 cm | Weight | 22.4 kg | Environmental Standards | TCO Certified Desktops 8 | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Workstation |
Product Form Factor | Tower - 5U |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Xeon Silver 4108 |
Clock Speed | 1.8 GHz |
Max Turbo Speed | 3 GHz |
Number of Cores | 8-core |
CPU Qty | 1 |
Max CPU Qty | 2 |
CPU Upgradability | Upgradable |
CPU Socket | FCLGA3647 Socket |
Chipset Type | Intel C622 |
Cache Memory | |
Installed Size | L3 Cache - 11 MB |
RAM | |
Installed Size | 32 GB / 768 GB (max) |
Technology | DDR4 SDRAM - ECC |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Memory Specification Compliance | PC4-21333 |
Form Factor | DIMM 288-pin |
Slots | 24 (Total) / 20 (empty) |
Features | Registered, mixing of different types of memory modules is not supported, slots 13 - 24 are available in two-processor configuration only, 6-channel memory architecture, non-uniform memory architecture |
Configuration Features | 4 x 8 GB |
RAM Supported | PC4-21300 - 3 TB Load-Reduced - ECC , PC4-21300 - 768 GB registered - ECC |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 10 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | No graphics |
Audio Output | |
Sound Output Mode | Stereo |
Compliant Standards | High Definition Audio |
Networking | |
Interface (Bus) Type | PCI Express |
Ethernet Ports | 2 x Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az, IEEE 1588v2 |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 4 (total) / 3 (free) x internal 2.5" / 3.5" shared |
Slots | 2 (total) / 2 (free) x PCIe 3.0 x4 , 4 (total) / 4 (free) x PCIe 3.0 x16 , 3 (total) / 3 (free) x PCIe 3.0 x8 |
Interfaces | 1 x headphones/microphone (1 in front) , 7 x USB 3.1 Gen 1 , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x serial , USB 3.1 Gen 1 (one of them is charging) , 4 x USB 3.1 (one of them is charging) , 2 x USB-C 3.1 Gen 2 |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, WEEE, Directive 2006/66/EC, ACPI 5.0, low halogen |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Efficiency | 90% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro for Workstations Plus 64-bit Edition English |
Sustainability Information | |
TCO Certified | TCO Certified Desktops 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 21.59 cm |
Depth | 55.12 cm |
Height | 44.45 cm |
Weight | 22.4 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 85% (non-condensing) |
