We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
Product Description | HP ZBook 17 G4 Mobile Workstation - 17.3" - Intel Xeon - E3-1535MV6 - 32 GB RAM - 512 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Xeon E3-1535MV6 / 3.1 GHz, up to 4.2 GHz / 8 MB Cache | Memory | 32 GB DDR4 (2 x 16 GB) | Storage | 512 GB SSD - SED, HP Z Turbo Drive, TCG Opal Encryption 2, NVMe, TLC | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro P3000 / Intel HD Graphics P630 | Video Memory | 6 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad, pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 6-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, smart card reader | Colour | Space Silver | Dimensions (WxDxH) | 42 cm x 28 cm x 3.3 cm | Weight | 3.14 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Xeon E3-1535MV6 / 3.1 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM238 |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 32 GB (2 x 16 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - ECC |
Speed | 2400 MHz / PC4-19200 |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 512 GB SSD M.2 2280 PCIe - Self-Encrypting Drive, HP Z Turbo Drive, TCG Opal Encryption 2, NVM Express (NVMe), triple-level cell (TLC) |
RAID Level | RAID 0, RAID 1 |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) anti-glare |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA Quadro P3000 / Intel HD Graphics P630 |
Video System Features | NVIDIA Optimus, Shader Model 5.0 |
Camera | Yes - 720p |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 720p HD movie recording, low light enhancement |
Sound | Stereo speakers, two microphones |
Codec | CX7501 |
Compliant Standards | High Definition Audio |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Features | Wake-on-LAN (WOL), dual stream (2x2) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2 |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 96 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 200 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | VGA , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 3.0 (charging) |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | Fingerprint Software, Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Secure Erase, HP Security Manager, HP Manageability, CyberLink Power Media Player, HP Client Catalog, Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP Touchpoint Manager, HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Features | HP 3D DriveGuard, HP DuraKeys, One-Step Logon, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3 |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+ |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3.14 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
