Perfect for engineering, visualization and Machine Learning, HP's most popular workstation delivers disruptive performance for a wide spectrum of applications. With a choice of Intel Xeon or Core X processors, and support for dual extreme graphics, you get all you need, nothing more.
Product Description | HP Workstation Z4 G4 - MT - Xeon W-2102 2.9 GHz - vPro - 8 GB - HDD 1 TB - UK | Type | Workstation - mini tower | Platform Technology | Intel vPro Platform | Height (Rack Units) | 4U | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Xeon W-2102 / 2.9 GHz (Quad-Core) | Processor Socket | LGA2066 Socket | Processor Main Features | Hyper-Threading Technology | Cache Memory | 8.25 MB | Cache Per Processor | 8.25 MB | RAM | 8 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-20800 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | HDD 1 TB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD-Writer | Graphics Controller | No graphics | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro for Workstations 64-bit Edition | Colour | Black | Dimensions (WxDxH) | 16.9 cm x 44.5 cm x 38.6 cm | Weight | 11.3 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Workstation |
Product Form Factor | Mini tower - 4U |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Xeon W-2102 |
Clock Speed | 2.9 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA2066 Socket |
Chipset Type | Intel C422 |
Cache Memory | |
Installed Size | 8.25 MB |
RAM | |
Installed Size | 8 GB / 256 GB (max) |
Technology | DDR4 SDRAM - ECC |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Memory Specification Compliance | PC4-20800 |
Form Factor | DIMM 288-pin |
Slots | 8 (Total) / 7 (empty) |
Features | Registered |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 6 |
RAID Level | RAID 0, RAID 1, RAID 10 |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | No graphics |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), PXE support |
Expansion / Connectivity | |
Bays | 2 (total) / 1 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5" |
Slots | 2 (total) / 2 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 1 (free) x M.2 Card |
Interfaces | 8 x USB 3.1 Gen 1 , 1 x headphones/microphone , 2 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 2 x USB-C , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, RoHS, FIPS 140-2, Common Criteria EAL4+, WEEE 2002/96/EC, ISO 11469, ISO 1043 |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 750 Watt |
80 PLUS Certification | 80 PLUS |
Efficiency | 90% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro for Workstations 64-bit Edition English |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 16.9 cm |
Depth | 44.5 cm |
Height | 38.6 cm |
Weight | 11.3 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 85% (non-condensing) |
