Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
HP Z24f G3 24"1920x1080 5ms HDMI DisplayPort IPS LED Monitor
free standard delivery
£260.59
34 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Get remarkable color accuracy and precise, vibrant detail with 99% sRBG color gamut and Full HD resolution.
  • Meticulously crafted with a frameless design this 23.8" (60.45 cm) diagonal screen monitor has 4 way ergonomic adjustability so you can work comfortably.
  • Experience exceptional vibrancy with HP Eye Ease, the always on low blue light filter that reduces blue light exposure with zero impact to true color accuracy.
  • Its plastics consist of over 80% recycled materials plus it has 100% sustainably sourced and recyclable packaging.
  • Diagonal Size: 24in, 23-25 inches
  • Max Resolution: 1920 x 1080, Widescreen
  • Response Time: 5ms, 4-8ms
  • Speakers: None, No Speakers
  • Interfaces: HDMI, DisplayPort
Product codes
chevron icon
chevron icon
Meticulously crafted to surpass every design standard, the HP Z24f G3 FHD Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise Full HD resolution. Refine your work experience and transform your PC into a powerhouse with this 23.8-inch diagonal screen monitor.
chevron icon
Product Description HP Z24f G3 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class D
Power Consumption (On mode) 12.5 W
Features USB 3.2 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.274 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey with overdrive)
Input Connectors HDMI, 2xDisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Voltage (50/60 Hz)
Colour Silver
Dimensions (WxDxH) - with stand 53.84 cm x 19.5 cm x 48.93 cm
Weight 4.7 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CECP, CEL, EAC, SEPA, BIS, DisplayPort 1.2, UAE, Ukraine Energy Label
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£260.59
