Our thinnest, lightest ZBook ever provides true portability for people who push their typical office computer past the breaking point. Whether in the office or out in the field, you'll get high-speed, reliable performance.
Product Description | HP ZBook 14u G6 Mobile Workstation - 14" - Core i5 8265U - 8 GB RAM - 256 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache | Memory | 8 GB DDR4 (2 x 4 GB) | Storage | 256 GB SSD - NVMe, TLC | Display | 14" WLED 1920 x 1080 / Full HD | Graphics | AMD Radeon Pro WX 3200 / Intel UHD Graphics 620 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, pointing stick, ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet | Battery | 3-cell | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 32.6 cm x 23.43 cm x 1.79 cm | Weight | 1.48 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8265U / 1.6 GHz |
Max Turbo Speed | 3.9 GHz |
Number of Cores | Quad-Core |
Cache | L3 - 6 MB |
64-bit Computing | Yes |
Memory | |
RAM | 8 GB (2 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2400 MHz |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC) |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | WLED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 250 cd/m² |
Colour Gamut | 45% NTSC |
Features | Full HD anti-glare |
Keyboard Name | HP Collaboration |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | AMD Radeon Pro WX 3200 / Intel UHD Graphics 620 |
Camera | Yes - HD |
Video Resolutions | 720p |
Camera Features | IR camera |
Sound | Stereo speakers, dual array microphone |
Audio Features | Bang & Olufsen Audio |
Input | |
Type | Keyboard, pointing stick, ClickPad |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch clickpad, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, NFC, Bluetooth 5.0 |
Wireless Controller | Intel Wireless-AC 9560 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Features | Dual stream (2x2) |
Compliant Standards | IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 3-cell lithium polymer |
Capacity | 50 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt |
Connections & Expansion | |
Interfaces | USB 3.1 (charging) , Headphone/microphone combo jack , LAN , Dock , USB-C 3.1 (supports Thunderbolt 3) , HDMI , USB 3.1 |
Miscellaneous | |
Dockable | Yes |
Features | Power On Authentication, Pre-boot Authentication, Master Boot Record Security, Microsoft Security Defender |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, CCC, FCC, MIL-STD 810G, KCC, A-Tick, ICES, CIT, ICCP |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.48 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
