Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need.
Product Description | HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Intel Core i7 - 8750H - 8 GB RAM - 256 GB SSD - UK | Product Type | Mobile workstation - flip design | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache | Memory | 8 GB DDR4 (2 x 4 GB) | Storage | 256 GB SSD - TLC + 16 GB SSD cache (3D Xpoint (Optane)) | Display | 15.6" LED backlight touchscreen 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro P1000 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0 | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) | 36 cm x 25.4 cm x 2.04 cm | Weight | 2.22 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8750H / 2.2 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
Cache | L3 - 9 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM246 |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (2 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 256 GB SSD 2.5" SATA - triple-level cell (TLC) |
SSD Cache | 16 GB 3D Xpoint (Optane) |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 400 cd/m² |
Features | Ambient light sensor, Corning Gorilla glass 4 |
Keyboard Name | HP Collaboration |
Audio & Video | |
Graphics Processor | NVIDIA Quadro P1000 |
Video System Features | NVIDIA Optimus, Shader Model 5.0 |
Sound | Stereo speakers |
Compliant Standards | High Definition Audio |
Audio Features | Output: Bang & Olufsen Audio, HP Clear Sound Amp |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, multi-gesture clickpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Wireless Controller | Intel Wireless-AC 9560 - PCI Express Mini Card (M.2) |
Compliant Standards | IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell lithium polymer |
Installed Qty | 1 |
Capacity | 64 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 150 Watt, 19.5 V |
Connections & Expansion | |
Slots | 2 x M.2 Card (1 free) |
Interfaces Details | 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | HP Remote Graphics Software, HP Performance Advisor, Windows Defender, Device Access Manager, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4 |
Miscellaneous | |
Features | Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Measured Boot, Power On Authentication, HP Fast Charge, Pre-boot Authentication, HP Sure Start Gen 4, HP Sure Recover, BIOS Update via Network, HP Sure Click |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.22 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
